Heated Seats wiring
Heated Seats wiring
by clinty » Tue Sep 27, 2005 3:42 pm
<div align="left">I have bought myself leather seats for my SE8, I am wondering has the SE8 got the wiring loom for them? also where would be the best place to get the heated seat switches fitted?
</div>
clinty
by Proxie » Tue Sep 27, 2005 4:15 pm
All the Calibras i saw was prepared for seat heater.. There should be connector under your seats AND behind ash-tray for the switches.
The original switch location is below ash-tray (you need a 'switch-holder' - fittet with one skrew).
Proxie
by callymental » Tue Sep 27, 2005 4:15 pm
Heated seat switches will be easiest placed where they are as standard. Below the ashtray infront of the gearstick. I have a housing for sale, with TC switch, but only blanks where the heated switches go.
You should have the wiring for them. Try lifting the carpet. Should see them there.
callymental
by clinty » Tue Sep 27, 2005 4:39 pm
That will do nicely fellas!! thank you for your advice! [img]/smile.gif[/img]
clinty
by chief » Wed Sep 28, 2005 8:23 pm
mate, i've fitted the heated seats to my se8. the main swich wiring was tucked up behind the ashtray taped to the main loom. however i couldnt find the wiring for the seats so i did my own, very simple all colour coded. two wires per seat ones a neutral the other is the switch wire (red/black & yellow/black if i remember ) connect up under the seat then run them to the swich plug and scotch lock them to there corisponding colour easy. any probs pm me
chief
by ROG » Wed Sep 28, 2005 8:34 pm
when i fitted the leather to my 16v the wiring for the front seats was just behind the front lump on the floor that the seats bolt to, but it was under ther carpet and the 1.5" of soggy wet foam!, both were coiled up and attatched to the metal on the pasenger side, id have never found it if i hadent been changing the carpet to cream, then i found the wet sponge and decided to take it out and dry it, then i found the wiring.,
ROG
by kev208 » Wed Sep 28, 2005 8:42 pm
[QUOTE=Proxie]All the Calibras i saw was prepared for seat heater..
do you mean every type of cally or just the se versions?
kev208
by chief » Thu Sep 29, 2005 8:37 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->when i fitted the leather to my 16v the wiring for the front seats was just behind the front lump on the floor that the seats bolt to, but it was under ther carpet and the 1.5" of soggy wet foam!, both were coiled up and attatched to the metal on the pasenger side, id have never found it if i hadent been changing the carpet to cream, then i found the wet sponge and decided to take it out and dry it, then i found the wiring.,<!--QuoteEnd--></div><!--QuoteEEnd-->
perhaps i missed it then mate, as i didnt change the carpet,thought i'd looked everywhere, oh well works a treat now anyway.
chief
by clinty » Tue Oct 04, 2005 5:42 pm
Any pics of where I can find the wires? I took the seats out on Saturday, me & my mate couldnt see the wiring for them!! [img]/sad.gif[/img]
clinty
by RobbieV » Tue Oct 04, 2005 6:33 pm
[QUOTE=kev208][QUOTE=Proxie]All the Calibras i saw was prepared for seat heater..
do you mean every type of cally or just the se versions?[/QUOTE]
All Calibra's [img]/wink.gif[/img] [img]/smile.gif[/img]
