I have a faulty abs sensor.
by AndiSe5 » Mon Oct 03, 2005 5:26 pm
Can anyone point me in the rite direction of fault finding and codes etc.
Many Thanks
AndiSe5
by RobbieV » Mon Oct 03, 2005 5:32 pm
<a href="http://www.topbuzz.co.uk" target="_blank">www.topbuzz.co.uk</a> [img]/smile.gif[/img]
by AndiSe5 » Mon Oct 03, 2005 5:38 pm
Spot on, thats the very site i had in mind.
Thank you. [img]/smile.gif[/img]
AndiSe5
by AndiSe5 » Mon Oct 03, 2005 5:56 pm
Ok fault shows : 25 - Faulty Sensor toothed Ring, gear - Incorrect gear. Check condition of the teeth on crown wheel/toothed ring.
So i guess it means that the teath are just dirty ?
And seeing as i put new Cv's on the front 6 months ago im guessing its the rears that will need doing ?
AndiSe5
by Kieran_Burns » Mon Oct 03, 2005 6:09 pm
carb cleaner and a polish on the crowns should sort you then - I had the damn' light flashing on mine after every bout of crappy weather... it got predictable in the end
Kieran_Burns
by AndiSe5 » Mon Oct 03, 2005 6:21 pm
Found the fault, and i dont think a good clean will do some how [img]/smile.gif[/img]
AndiSe5
by RobbieV » Mon Oct 03, 2005 6:28 pm
Well thats an easy to spot problem then [img]/smile.gif[/img]
by Kieran_Burns » Mon Oct 03, 2005 6:46 pm
Holy Cow!!! I think you may be right there [img]/biggrin.gif[/img]
Kieran_Burns
by AndiSe5 » Mon Oct 03, 2005 7:09 pm
When the ring is on the hub the space at the crack is even bigger.
So good old autovax will be called tomorow for 2 new ones and a drop linq whilst im at it as the boot has split on one of them.
AndiSe5
by AndiSe5 » Tue Oct 04, 2005 5:18 pm
BAAAD news
Vauxhall no longer sell the part that im after, unless i buy the whole hub !
So will anyone be able to donate one to me ?
AndiSe5
by King Calibra » Tue Oct 04, 2005 10:35 pm
Is rust realy such a big problem in the UK? I've never seen an ABS ring look that bad! :eek:
King Calibra
by Proxie » Wed Oct 05, 2005 2:37 am
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Is rust realy such a big problem in the UK? I've never seen an ABS ring look that bad! :eek:<!--QuoteEnd--></div><!--QuoteEEnd-->
Yeah I think so.. same problem in Denmark.. Our weather/air is filled with salt (sea and stuff You know). To just make it worse we use salt to clean roads for snow and ice.
Essential to underbody treatment then! Products like Dinitrol, Pava and Tectyl are probably not known in Germany [img]/smile.gif[/img]
Viele autos sind Verkauft nach Dänemark für ausslachten [img]/smile.gif[/img] 90% von Deutchland [img]/biggrin.gif[/img] (sorry for my ****ty german)
Proxie
by AndiSe5 » Wed Oct 05, 2005 4:44 pm
Thanks but that dont help me find a new abs ring does it [img]/smile.gif[/img]
AndiSe5
by Proxie » Wed Oct 05, 2005 6:07 pm
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->Thanks but that dont help me find a new abs ring does it [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry..a bit off topic but i can maybe find a ring for ya. We've scrapped a lot off Calibras [img]/smile.gif[/img]
How many teeth is on the ring? (we have some parts mixed with Vectra 2000 and Calibra - some differs in ABS )
Proxie
by AndiSe5 » Wed Oct 05, 2005 10:32 pm
Its the 29 tooth type please [img]/smile.gif[/img] .................... please tell me you have at least one.
AndiSe5
