Vaux Power steering fluid?? for turbo 4x4??
anyone have a part number?? mines low!!!! lol
Cheater2k
you need to run the car a bit, to pump the rpessure up, then turn the engine off, turn the ingnition on then pump the brake slowly untill the whooses stop, then check the level, theres 2 marks on the dipstick one for hot and one for cold pas fluid
unless you do this you cant see the fluid level the bottle should look empty normaly
dont overfill it unless you like washing the engine bay , itl all squirt out of the bottle all over the place when you check the level
ROG
abit tatty at the moment, lol, cos i havnt had time to clean her for 3 weeks, will be done this weekend.
but shes coming off the road when i can afford the GTX abs plastic kit. and having a full repsray
at the moment im just getting engine, 4x4 and suspension set up 150% [img]/smile.gif[/img]
Cheater2k
