95 calibra turbo --- brakes question
by CAL.16V » Thu Oct 06, 2005 3:20 pm
hi........
i am after a set of front brake pads for my cali built in 6/95 and complied first here in australia in 96.......
the ebc greenstuff page has 2 listings for front....
93-95 brake pads and 95-98 pads
i know one has 284mm and one has 288mm....... how do i tell which pads mine takes before ordering them online???
CAL.16V
by Cheater2k » Thu Oct 06, 2005 6:01 pm
measure you disks, that will tell you which pads.
Cheater2k
by CAL.16V » Fri Oct 07, 2005 4:35 am
hmm... so no way of knowing from engine or chassis numbers???
i am sure vauxhall wont go tell you to measure your discs when you want to buy brake pads off them???
anyways,
which ways is it??
93-95 have 288mm
and
95-98 have 284 mm???
or the other way around?
CAL.16V
by Cheater2k » Fri Oct 07, 2005 5:37 am
if your a mechanic, and fitting them yourself, thats exactly what they tell you do to mate [img]/smile.gif[/img]
Cheater2k
by CAL.16V » Tue Oct 11, 2005 3:29 am
sorted i got 284mm brakes which kinda sucks because 288 discs are alot cheaper but i just got some cheap greenstuff pads
CAL.16V
