elctric windows
elctric windows
I had a new dooe sprayed put he took everything out to spray.So I had to remove all the guts from mine into the new one,but now Iv got the window to stop in the right place with the stoper thingy but Iv the window goes up on auto or by the alarm when it gets to the top it goes back down as if something is trapped.Please help as I cant arm my alarm till its fixed.
rob
if the windows are going back down it must mean there is some resistance, cos u know they goe back down if there is resistance so kiddies don't lose their heads!
Maybe you have to 'bring the window down' a little bit if possible on the rollers? maybe as it gets to the top its trying to go that little bit further but can't, so goes down?
just an idea mate
just an idea mate
Iva Biggen
i was told about this a few days ago, look down the door under the locking catch, there a big rubber blanking grommet, pull that off and look inside about 2 inches, there s a nut, this adjusts the alignment of the window according to how much pressure it makes towards the top to stop water leaking in, it sounds like you need to adjust it off very very slightly to stop water getting in but enough for it to slide up, also put vaseline on the rubber edges where the window rubs it, that'll help as well
richardworrall
Users browsing this forum: Majestic-12 [Bot] and 13 guests
