Brake Recommendation Pls
HI,
Can someone recommend a good make of brake pads and discs, I know nothing about them so not sure where to look.
The ones I have on at the moment are like the cheapest make ever and squeek like mad. Id really like some decent ones.
Thanks in advance.
Thanks in advance.
Alcofrolic
hi ya. try to buy spares from a motor factor .. they supply garages etc. so normal they have good quality stuff as standard. also get a tube of copper grease. put it on the edeges of the pad that touch the caliper and also on the back of the pads. a blob about smartie size rub over the back. this helps pads to slide and should stop the brake squeel. clean the claiper with a wire brush before fitting the new pads. hope this helps.
nicc from notts
Fostersice17
Alcofrolic
