Security
<!--QuoteBegin-joeraz+--><div class='quotetop'>(joeraz)</div><div class='quotemain'><!--QuoteEBegin-->Mr Toad, i had a Ai606 fitted a few months back, my remte has 4 buttons and i currantly only use 3 of them,, do i have a spare channel & if so,, what could i use it for? i do have full closure just now.
cheers<!--QuoteEnd--></div><!--QuoteEEnd-->
You have 3 channels
one for total closure
one for 1" boot release
and on if you hold both bottom buttons together you get an output for as long as held
Ian
You have 3 channels
Ian
MR_TOAD
<!--QuoteBegin-Turbochops+--><div class='quotetop'>(Turbochops)</div><div class='quotemain'><!--QuoteEBegin-->Hi Toad
Ive got a toad alarm fitted to my car, R plate V6, but when i bourght the car, there was no paper work that came with relating to the alarm.
My insuracnce company want to know the exact system fitted, as apprantly just saying its a Toad wont do. Is there anyway of intentifying the model from just looking at the car.
If it helps the remoting locking fob has 4 buttons 2 big ones green and black which are used to open/lock the car and another 2 smaller buttons which i dont know what they do. There is a light by the side of the gearstick, which flashes green/amber.
Thanks
Turbochops<!--QuoteEnd--></div><!--QuoteEEnd-->
What does the siren look like is it a square and have a green front
as thay do a A201TC that has the same fob
Ian
Thanks
Ian
MR_TOAD
Hi, I have a toad immobilizer on my car, and I’m going to fit a remote start alarm, (any tip much appreciated).
Where is the control box for the immobilizer usually hidden, and what does it immobilize and where, I can't see any cut wires around the fuse box? I need to temporally bye pass the immobilizer for the remote start to work. I know it cuts the supply to the ignition but can’t find any cut wires?
Shakey J
<!--QuoteBegin-Shakey J+--><div class='quotetop'>(Shakey J)</div><div class='quotemain'><!--QuoteEBegin-->Hi, I have a toad immobilizer on my car, and I’m going to fit a remote start alarm, (any tip much appreciated).
Where is the control box for the immobilizer usually hidden, and what does it immobilize and where, I can't see any cut wires around the fuse box? I need to temporally bye pass the immobilizer for the remote start to work. I know it cuts the supply to the ignition but can’t find any cut wires?<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry without looking at car i could not tell you
Ian
Ian
MR_TOAD
Ahhh Mr Toad... you might be just the man. I bought a TOAD Ai606 brand new and boxed form ebay some time ago and can't be arsed to fit it. I live near Oxford but my brother, who I visit quite often, lives in Wakefield. How much would you charge to fit the alarm/immob bearing in mind that there is an old CONLOG alarm/immob currently fitted. I should be up to Yorshire in a few weeks to pick up some Oxy-Acetylene gear from my brothers house.
MickM
<!--QuoteBegin-MickM+--><div class='quotetop'>(MickM)</div><div class='quotemain'><!--QuoteEBegin-->Ahhh Mr Toad... you might be just the man. I bought a TOAD Ai606 brand new and boxed form ebay some time ago and can't be arsed to fit it. I live near Oxford but my brother, who I visit quite often, lives in Wakefield. How much would you charge to fit the alarm/immob bearing in mind that there is an old CONLOG alarm/immob currently fitted. I should be up to Yorshire in a few weeks to pick up some Oxy-Acetylene gear from my brothers house.<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--coloro:red--><span style="color:red"><!--/coloro-->Your looking to strip out and refit new system £120.00<!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--coloro:red--><span style="color:red"><!--/coloro-->Thats with certificate stamped etc<!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--coloro:red--><span style="color:red"><!--/coloro-->[/color]<!--sizec--></span><!--/sizec-->
<!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->[color=red]Regards Ian<!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec-->
MR_TOAD
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Your looking to strip out and refit new system £120.00
Thats with certificate stamped etc<!--QuoteEnd--></div><!--QuoteEEnd-->That sounds okay... I'll be in touch next time I head up north - soon hopefully. How much notice do you need and how long does it normally take..? Whereabouts are you in West Yorks..?
MickM
Hi Mate im in Leeds it would take on a calibra about 2-2.5 hours
Try and give me as much notice as possible it would be a week day
I can get into a garage if the weather turns bad
Best Regards Ian
<!--QuoteBegin-MickM+--><div class='quotetop'>(MickM)</div><div class='quotemain'><!--QuoteEBegin-->That sounds okay... I'll be in touch next time I head up north - soon hopefully. How much notice do you need and how long does it normally take..? Whereabouts are you in West Yorks..?<!--QuoteEnd--></div><!--QuoteEEnd-->
Best Regards Ian
MR_TOAD
ok now im well p1ssed. i rang a load of guys to try and get some sort of contact. eventually found someone who had dealt with these sigma alarms before. told me i couldnt even get these key fob replaced, so i bit the bullet and opened it up. need to replace 2 batteries in it, except the buggers hav soldered them in. so off i went searching for a new key fob again on the net and by chance i came across them. but they are 30 + vat + p&p to ireland and i cud do wit gettin a spare as both are fairly down on juice at the mo. question is would i get a good enuf new system for not much more than this? <a href="http://www.hickleyvaltone.com/diagnostics/keys_list.php?range=sigma" target="_blank">http://www.hickleyvaltone.com/diagnostics/...php?range=sigma</a>
its the hvac18 type
or if someone else knows where i could get these cheaper or even a universal fob(that batteries can be changed on) that would be great.
its the hvac18 type
johnny_adidas
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->1 more question, if i bought, say a new toad alarm, would it just be a simple matter of swapping the control boxes and away i go. this may be the easiest way around it if i could<!--QuoteEnd--></div><!--QuoteEEnd-->
Easiest way to go as you get booklet guarentee etc
Er Not plug and play but i could talk you through it
Regards Ian
Regards Ian
MR_TOAD
ok may have another solution, a code learning remote. could also put my other car on a diff button which wud b real handy. do you know if it would work as it says
IT WILL NOT Duplicate "Code-Rotating," “rolling Code "Mega-Code," or Intellicode & Security +
<a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=6011337902" target="_blank">http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=6011337902</a>
johnny_adidas
Users browsing this forum: Bing [Bot] and 12 guests
