Knocking (ANOTHER PROBLEM)
by dicky » Fri Oct 28, 2005 6:55 pm
Well i have also noticed that my new car has a loud knock when u turn the wheel or accelerate and decelerate and it can be felt through the wheel.
Feels like its drivers side only.
Any ideas?
dicky
by ROG » Fri Oct 28, 2005 7:23 pm
engine/gearbox mounts, also stops it going into gear as easily
ROG
by dicky » Fri Oct 28, 2005 7:35 pm
So the problem with my gears and knock is the same?
Is that expensive?
dicky
by ROG » Fri Oct 28, 2005 8:38 pm
the mounts dont cost much, im not sure how much though, and there just a bolt on / off job, autovaux list the parts on there site,
i thought mine had gone the other day as when i accelerated hard there was a knocking, theyve all been replaced before, i was going to have a good look when i got home, but i over took a lorry....
the bracket holding the mount snapped and locked the engine and wheels , ive never heard of this happening before!
ROG
by dicky » Fri Oct 28, 2005 9:26 pm
hmmm, it does the same knock when i steer, could it not be anti-roll bar or lower arm ball joints?
dicky
by daddycool » Fri Oct 28, 2005 9:49 pm
I would say it sounds like a lower suspension arm bush.
daddycool
by Monkey » Fri Oct 28, 2005 10:52 pm
I would've thought outer CVs.
Monkey
by daddycool » Fri Oct 28, 2005 10:55 pm
<!--QuoteBegin-Monkey+--><div class='quotetop'>(Monkey)</div><div class='quotemain'><!--QuoteEBegin-->I would've thought outer CVs.<!--QuoteEnd--></div><!--QuoteEEnd-->CV joints make more of a 'grumbling' noise or a constant knock-knock-knock.
Not just a singular 'Knock'.
daddycool
by Will » Fri Oct 28, 2005 11:10 pm
Must be the weather for it!! Mine's just developed a knock under the same conditions. I could hear it strongest offside front. Just had a look over, found that me anti roll bar bushes are worn. The inner wrap around bushes.
Have a look where the bush wraps around the bar, if theres a bit of a gap between the bar and bushe, that'll be worn!
Not sure if the bushes are available separately, find out Monday!
Will
by Monkey » Fri Oct 28, 2005 11:15 pm
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->CV joints make more of a 'grumbling' noise or a constant knock-knock-knock.
Not just a singular 'Knock'.<!--QuoteEnd--></div><!--QuoteEEnd-->
Ahh good point, I hadn't realised it wasn't constant. Its annoying when the CVs go though.
Monkey
by MickM » Sat Oct 29, 2005 7:16 am
Ball joints or lower arm bushes... I've just had a problem with knocking on mine under braking and acceleration. Turned out to be badly fitting aftermarket brakepads. Last thing I changed too... Typical...!!!
MickM
by ROG » Sat Oct 29, 2005 10:12 am
knocking and also trouble changing gear ( other post ), more likely to be engine mounts i think, when the wishbone bushes and antirollbar links went on mine, only knocked when going over a bump
ROG
by MickM » Sat Oct 29, 2005 4:41 pm
Sorry... not seen other post... My engine nearly fell out quite a few years back when one of my engine mounts actually snapped. One of the bolts was missing and the engine was just held in by one bolt on the nearside...
MickM
by Rusty_CallyT » Sat Oct 29, 2005 4:48 pm
i will throw in a wild card here.. loose subframe mounting bolt? lol
Rusty_CallyT
Users browsing this forum: Bing [Bot] and 9 guests
