Security
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->ok may have another solution, a code learning remote. could also put my other car on a diff button which wud b real handy. do you know if it would work as it says
IT WILL NOT Duplicate "Code-Rotating," “rolling Code "Mega-Code," or Intellicode & Security +
<a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=6011337902" target="_blank">http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=6011337902</a><!--QuoteEnd--></div><!--QuoteEEnd-->
No good rolling code
Ian
Ian
MR_TOAD
looks like im after being fleeced anyway, purchased it and then ebay shut them down. claiming back by paypal now if i can. tink i might not be in as much trouble as first thought doh. while i had it opened i noticed a blue thing that had come away from where it should be. think it is the transmitter, gona solder it back and see. my second fob is working fine at d mo so fingers crossed that is all that is wrong with this one.least it will keep me goin til i can afford a new system anyway
johnny_adidas
<!--QuoteBegin-cal2616v-(Baz)+--><div class='quotetop'>(cal2616v-(Baz))</div><div class='quotemain'><!--QuoteEBegin-->hi,
i have a meta system ,it was on the calibra when i bought it but i dont have the model type or any serial numbers .
I wanted to know if if it maybe a cat 1 or cat 2 alarm but im not sure where i might find the module
any suggestions<!--QuoteEnd--></div><!--QuoteEEnd-->
Will it immobilise car if you dont start it within 30 seconds or so
Ian
Ian
MR_TOAD
yes thats correct ,the immobiliser is under the dash just under the steering wheel
basically you can go to start it and it will be dead until you put the transponder into the immobilsation hole then the car starts after 5 secs
but also if it did happen to be a categry alarm i dont have any certificate for my car insurance
Hi mr toad, ive got a clifford alarm and immobiliser in my cally, ( god knows what model it is) basically it keeps arming itself when im driving and i have to keep the bloody fob in my hand to turn it off, any idea why it might be doing this? any help would be appreciated! I had my car broken into last week and im having to use the ignition switch with a screw driver to start it lol! until my new barrel arrives - does the key have to be in the ignition to stop this or is it something else?
johnaspey
<!--QuoteBegin-johnaspey+--><div class='quotetop'>(johnaspey)</div><div class='quotemain'><!--QuoteEBegin-->Hi mr toad, ive got a clifford alarm and immobiliser in my cally, ( god knows what model it is) basically it keeps arming itself when im driving and i have to keep the bloody fob in my hand to turn it off, any idea why it might be doing this? any help would be appreciated! I had my car broken into last week and im having to use the ignition switch with a screw driver to start it lol! until my new barrel arrives - does the key have to be in the ignition to stop this or is it something else?<!--QuoteEnd--></div><!--QuoteEEnd-->
Sounds like it has lost its ignition feed
Check fuses
Ian
Check fuses
Ian
MR_TOAD
ian,
another quick question. lost my keys in the end so now im working on one set, doh!! so would a toad powerkey immobiliser be a direct swap for the touch key type immobiliser? meaning if i unplug the existing touch key interface(which i now only have one key for) from the control box and plug the new powerkey one in, will it work?
cheers,
cheers,
johnny_adidas
