tranforming to non pas
by Monkey » Fri Nov 11, 2005 12:10 pm
Ahhh, one day I will learn to read all of the thread!
Monkey
by Naz » Fri Nov 11, 2005 1:40 pm
<!--QuoteBegin-nariman1977+--><div class='quotetop'>(nariman1977)</div><div class='quotemain'><!--QuoteEBegin-->How do you mean Will, bulkhead flexed too much?!! by runnig no PAS?!!
In the std setup with PAS, when you run it without, you still have to push the fluid inside the steering and the whole system to left and right when you turn it. But if you use a column thats not a PAS column, then you don't have that problem. Most of the problem then comes from how big your wheels are and ...<!--QuoteEnd--></div><!--QuoteEEnd-->
And there was an even earlier answer to the above point [img]/wink.gif[/img]
Why don't people read?!!! [img]/tongue.gif[/img]
Naz
by Naz » Fri Nov 11, 2005 1:42 pm
<!--QuoteBegin-ealex+--><div class='quotetop'>(ealex)</div><div class='quotemain'><!--QuoteEBegin-->so how do you reinforce the bulkhead? Any way of welding some bars or anything?<!--QuoteEnd--></div><!--QuoteEEnd-->
probably having a strut brace will help a bit.
Apart from that, ican;t say i have noticed it before. Something i will notice when i come to put the engine back in.
Naz
by Chavtastic » Sat Nov 12, 2005 11:59 am
If you use a non-PAS rack from a Cavalier, make sure it has an airbag, because non-airbag steering columns are different.
by Naz » Sun Nov 13, 2005 2:19 am
<!--QuoteBegin-Chavtastic+--><div class='quotetop'>(Chavtastic)</div><div class='quotemain'><!--QuoteEBegin-->If you use a non-PAS rack from a Cavalier, make sure it has an airbag, because non-airbag steering columns are different.<!--QuoteEnd--></div><!--QuoteEEnd-->
Airbag won't make any diff to me at all as it has been removed already.
I can't understand how airbag makes it diff though?!! Its the rack not the column. I would understand if the column was diff, but rack?!!
Naz
by ealex » Sun Nov 13, 2005 3:09 am
did a check in this technical book i have on the cally, and it seems the only 2 things it doesnt cover are the airbags and steering. it says that those items should not be serviced. but i dont get why replacing them could be dangerous. i guess the only thing left is to take a trip to the breakers and compare them. will post update this week.
ealex
by Chavtastic » Sun Nov 13, 2005 11:00 am
Sorry... airbag makes the column different (on non-airbag it's adjustable and a different diameter), so possibly just the joint at the rack, or the rack itself could differ.
Worth checking to make sure... but possibly may be okay [img]/smile.gif[/img]
by ealex » Sun Nov 13, 2005 11:19 am
ok, so the column is different, i agree. but is there a difference in the racks? why would there be, i dont get it?
ealex
by Chavtastic » Sun Nov 13, 2005 11:23 am
I'm not saying there is! ... but it is worth checking rather than buying one, then finding it don't fit!
by Animal » Sun Nov 13, 2005 12:38 pm
I read somewhere they are different cos of the extra weight but I could be wrong. I think I read that over on cav web some time back.
by Naz » Sun Nov 13, 2005 12:41 pm
I bought a brand new one off ebay for £20!1 Bargain i thought. Its a gen Vaux one and its for Cav Mk3 but he says it fits others.
Will try it out in the next few weeks once i get a chance and then let you all know.
p.s. Not ALL turbos have adjustable steering column. Mine has airbag but no tilted column. My 16valver had adjustable column and airbag!
Naz
by Toddy » Sun Nov 13, 2005 6:48 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Not ALL turbos have adjustable steering column<!--QuoteEnd--></div><!--QuoteEEnd-->
Mine doesn't;)
Toddy
by ealex » Sun Nov 13, 2005 6:59 pm
ok. so the non-pas rack will fit. who volunteers to be the first one to test its performance? [img]/wink.gif[/img] anyone here with too much free time on their hands?
ealex
by Naz » Sun Nov 13, 2005 7:27 pm
Well i will be trying mine later on and will let you know how it goes.
But tbh, if you plannig on using your car for road, then its better to keep the PAS as its much easier.
But with the non pas, you get more feedback through the steering and i think the DRIVING is much more pleasant, but turnings aren't [img]/wink.gif[/img] or parking [img]/biggrin.gif[/img]
Naz
by ealex » Sun Nov 13, 2005 8:14 pm
i will test it. but i will leave the pump and pipes on so that i can go back. probably this week.
ealex
