radiator fan
radiator fan
by ealex » Thu Nov 17, 2005 2:05 pm
im gonna be quick. my radiator fan does not start, temp slowly rises and holds between the two red lines. i couldnt find its fuse anywhere. although it is listed on the cover of the fusebox, there is no fuse connector in that position. i have no idea what to check first. i dont wanna go buy a new one and then find out its a fuse or its thermostat.
ealex
by nigw » Thu Nov 17, 2005 7:03 pm
the fuse for the coolingfan is the same one as the heater fan..i think
if the heater blower works it is probably the fan switch..
look here <a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a>
:ponder2:
nigw
by ealex » Thu Nov 17, 2005 9:32 pm
thanks a lot. will look into it tomorrow. however, why are they marked if there are no fuseholders in their places? just curious
ealex
by nigw » Thu Nov 17, 2005 10:45 pm
probably same fuse box used in different motors..
nigw
by kev208 » Thu Nov 17, 2005 10:56 pm
could be damp in the connecter stopping it working
kev208
by Fostersice17 » Thu Nov 17, 2005 11:05 pm
The fan does not come on until the engine gets very very hot,or about to over-heat,at least thats what the ecotec fan does.
Fostersice17
by nigw » Thu Nov 17, 2005 11:05 pm
i had both stop working together turned out to be the ignition switch.had to push the key in hard and they both came on .
luckily a simple job to sot out
nigw
by ealex » Thu Nov 17, 2005 11:07 pm
<!--QuoteBegin-kev208+--><div class='quotetop'>(kev208)</div><div class='quotemain'><!--QuoteEBegin-->could be damp in the connecter stopping it working<!--QuoteEnd--></div><!--QuoteEEnd-->
nope, checked that. besides, there's a rubber thingy that makes it waterproof
ealex
by nigw » Thu Nov 17, 2005 11:24 pm
ok i got it wrong bottom row fouth fuse in is the cooling fan.
top row fourth in heater fan, just been out and checked as it was bugging me.
bloody cold out there
:bash:
nigw
by SukySaggi » Fri Nov 18, 2005 10:26 am
The connector from the fan should go to the thermostat? in the radiator, if you short that out the fan should go on. If it does go on you need to change the thermostat? in the radiator if it doesn't go on then you may have a break in the wiring.
SukySaggi
by ealex » Sat Nov 19, 2005 1:12 pm
faulty wiring and a burnt jack on the fan made it go to heaven. put in new fan, and problem solved. kind of. i need to change the termostat relay on the radiator also, cus it only starts the low stage. however, if u short the wires of the thermostat it starts at maximum rpm. will have to wait for part to arrive on monday
ealex
