Headlight swap issues
by King Calibra » Wed Oct 26, 2005 3:47 am
Just installed my new headlamps with fogs.
When I installed the switch into the dash, I noticed that the light in the switch was very dim, and doesn't turn the lights on.....
Any clues?
Also, the height adjustment motor on the right side seems to "search" for proper adjustment every time I turn on the headlights. I can see the beam moving up,down,up,down, a few times....
King Calibra
by King Calibra » Sat Oct 29, 2005 4:40 am
anybody?
King Calibra
by nigw » Sat Oct 29, 2005 9:40 am
hoping to do mine this week let you know what happens...
the luck i have doin stuff like this probably blow something:roll:
nigw
by King Calibra » Sat Oct 29, 2005 7:23 pm
It's just a matter of connecting the 2 plugs to the headlight unit. It's that easy. All 3 plugs are different, so you can't mix them up.
When you remove the headlight from the car, it will all make sense. (I even did mine with the battery still connected, [img]/laugh.gif[/img] )
King Calibra
by nigw » Sat Oct 29, 2005 10:51 pm
my hero lol
nigw
by wilkybar-kid » Sun Oct 30, 2005 11:56 am
Sounds silly but, have you put a relay in the fuse box for the fog's. will explane why they arnt comming on.
wilkybar-kid
by wilkybar-kid » Sun Oct 30, 2005 11:57 am
If not just pull the one for the horn out and push it into the spoty below it for the fog's just to test
wilkybar-kid
by Robs-se » Tue Nov 15, 2005 3:26 pm
I have the switch and relay for the front fogs in my SE1
If i change the lights for ones with fogs is the wiring there
for it?
Rob
by King Calibra » Wed Nov 16, 2005 6:37 pm
yes, all calibras have the wiring in the main headlight harness already, it's as easy as installing the lights, the switch and the relay!
King Calibra
by Robs-se » Thu Nov 17, 2005 2:22 pm
Cheers... i'll now source some new headlights
Rob
