cv joint
cv joint
by 16VALVER » Thu Nov 17, 2005 2:43 pm
this sucks the cali is in the shop for a mot and they cant get a cv joint to work. its a 91. the splines on the shaft are correct one one but the abs gear is wrong and on the other one the asb gear is correct but the splines are wrong. someone help me please and quick i need it to go home tonight. it is the drivers side outer. please help!
16VALVER
by j4mes » Fri Nov 18, 2005 11:28 am
any luck yet??
j4mes
by 16VALVER » Fri Nov 18, 2005 11:59 am
sorted the part had to come from the stealership. i had to drive a rover 400 w/out heat home last night. but its cool i left them with f all for gas.
16VALVER
by j4mes » Fri Nov 18, 2005 12:08 pm
at least its sorted. a nice new cv joint with shiny abs teeth
j4mes
by 16VALVER » Fri Nov 18, 2005 12:31 pm
abs light still on though oh well it still passed
16VALVER
by j4mes » Fri Nov 18, 2005 12:51 pm
read the abs fault codes, could just be a dirty sensor
j4mes
by Phil69 » Sat Nov 19, 2005 1:21 am
That's odd, I always thought it was a failure if the light was on as this means the ABS is innoperative however if the vehicle has it, it should be working!
