Which brake fluid?
Which brake fluid?
by Monkey » Fri Nov 11, 2005 12:14 pm
I'll be putting 308mm brakes on my 8v soon with braided hoses so that I can actually get some braking power on my Calibra. Whilst I'm doing this I have been told that it's a good idea to renew the brake fluid every 2-3 years as it starts to absorb air and makes the brakes feel spongier (they are typically crap brakes!) and I'm not sure which to get as there are different grades to get 4.0, 5.0, 5.1 etc. Anyone got any knowledge on this?
Lee
Monkey
by Dan Willis » Fri Nov 11, 2005 1:34 pm
Just the usual stuff will do.. think that's 5.1.
Dan
by Naz » Fri Nov 11, 2005 1:39 pm
Usual stuff is a dot4. You can put them in, or you can go for the silicone type 5.1 fluid. A bit more expensive i think.
Naz
by dj_smurph » Sat Nov 12, 2005 1:25 pm
dot 5.1 has the highest temp rating gives less fade and about 50% more expensive
dj_smurph
by Monkey » Sat Nov 12, 2005 3:08 pm
Thanks guys, was a bit unsure so I'll have a look for some soon.
Monkey
by Toddy » Sun Nov 13, 2005 6:49 pm
5.1 it's not that expensive;)
Toddy
by dj_smurph » Sat Nov 19, 2005 7:09 pm
it is if your using ap racing
dj_smurph
by Monkey » Mon Nov 21, 2005 10:03 pm
Just one more Q, how much will I need? It tends to come in a 250ml or 500ml bottle.
Monkey
by Naz » Mon Nov 21, 2005 11:14 pm
Depends.
If you renewing the whole system you will need about 500ml of it.
BUt if you only topping up, then you need less.
Becarefull though: If you changing from dot4 to dot5.1 or anything else, you have to completely drain the brake system and refill, otherwise dot5.1 which is silicone based will turn into gunky stuff and f**k the system up.
Naz
by MickM » Mon Nov 21, 2005 11:15 pm
5.1 is more expensive and unnecessary really. In addition I'm sure I read that it doesn't last as long as it absorbs air and moisture more readily than standard stuff...?
MickM
by j4mes » Wed Nov 23, 2005 3:12 pm
it does need changing every year if you use 5.1, but it is much better if you suffer brake fade
j4mes
