Bigger alloys, standard springs
by SukySaggi » Wed Nov 23, 2005 10:34 am
If I fit 17's or 18's onto my cally and keep the standard springs, will I still have to fit camber correction bushes?
Do you only have to use the correction bushes when lowering the car?
SukySaggi
by j4mes » Wed Nov 23, 2005 10:37 am
you only reallyneed them when lowerining your car
j4mes
by Rosh » Wed Nov 23, 2005 4:54 pm
When I had my Calibra Turbo, I had a full uprated suspension kit (shocks and springs). Remember if you do fit lowering kit, you MUST get an Anti-Camber Correction Kit other wise you'll see your transfer box fail on you.
Rosh
Rosh
by nigescalli » Wed Nov 23, 2005 5:57 pm
it might look a bit like a off road vehicle on standard springs but not sure i think camber would be ok if its standard suspension
nigescalli
by johnny_adidas » Wed Nov 23, 2005 6:01 pm
as above, can look weird with wheels that size on a car thats not lowered
johnny_adidas
by AndiSe5 » Wed Nov 23, 2005 6:10 pm
A -30mm kit will be ok without a camber kit.
AndiSe5
by daddycool » Wed Nov 23, 2005 9:48 pm
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->A -30mm kit will be ok without a camber kit.<!--QuoteEnd--></div><!--QuoteEEnd-->Not in my opinion!
daddycool
by AndiSe5 » Thu Nov 24, 2005 12:03 am
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Not in my opinion!<!--QuoteEnd--></div><!--QuoteEEnd-->
Why ?
My calibra has it standard so why should it be bad ?
AndiSe5
by Stupink » Thu Nov 24, 2005 12:09 am
because your car has camber kit as standard.
by Munt » Thu Nov 24, 2005 12:38 pm
<!--QuoteBegin-johnny_adidas+--><div class='quotetop'>(johnny_adidas)</div><div class='quotemain'><!--QuoteEBegin-->as above, can look weird with wheels that size on a car thats not lowered<!--QuoteEnd--></div><!--QuoteEEnd-->
yeah i agree got mine on 18's with standard springs in dire need of being lowered, roll on christmas hopfully santa will have some for me!!!!
by AndiSe5 » Thu Nov 24, 2005 8:04 pm
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->because your car has camber kit as standard.<!--QuoteEnd--></div><!--QuoteEEnd-->
Thats what they say but i dont beleve it, i still have some + camber.
AndiSe5
by Stupink » Thu Nov 24, 2005 8:15 pm
A std callyT has some camber. its in the geometry spec.
Look up the part no for your rear arm bushes v's a std callyT rear arm bush.
