handbrake
handbrake
by Rusty_CallyT » Thu Dec 29, 2005 2:10 am
The handbrake on my eco is only holding 1 side.
It needs new discs and pads on the back anyway.
Is it just going to be a case of replacing the disc/drum, handbrake shoes and adjusting the cable or is it likely to need something else?
Its an N reg 16v ecotec
Rusty_CallyT
by RobbieV » Thu Dec 29, 2005 2:17 am
I replaced my rear drums, pads and shoes and fitted a new handbreak cable, Changed the flexi brake hose for some black diamond ones from Fatz and through the MOT and back out with a clean bill of health [img]/smile.gif[/img]
by wilkybar-kid » Thu Dec 29, 2005 2:20 am
It should give equel pull on each side any way due to the way they are cabled up, I am guessing it is where the pads are getting low....
... Rob, do your brakes feel any better now you have fuitted all that lot???
wilkybar-kid
by RobbieV » Thu Dec 29, 2005 2:27 am
<!--QuoteBegin-wilkybar-kid+--><div class='quotetop'>(wilkybar-kid)</div><div class='quotemain'><!--QuoteEBegin-->Rob, do your brakes feel any better now you have fuitted all that lot???<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh yes [img]/smile.gif[/img]
I did the whole brake system
new grooved front/rear discs.
New pads all round.
new handbrake shoes.
new handbrake cable.
black diamond stainless steel hoses front/rear.
new brake fluid.
my handbrake cable was only holding on one side and a mate suggested changing for a new one as it might have stretched it on one side.
by RobbieV » Thu Dec 29, 2005 2:34 am
<!--QuoteBegin-wilkybar-kid+--><div class='quotetop'>(wilkybar-kid)</div><div class='quotemain'><!--QuoteEBegin-->It should give equel pull on each side any way due to the way they are cabled up, I am guessing it is where the pads are getting low<!--QuoteEnd--></div><!--QuoteEEnd-->
The 2 parts of the cable used to pull the handbrake shoes are not made of equal lengths, and my old one was definitely stretched. i noticed it when i placed the old next to the new.[img]/smile.gif[/img]
by turbo i wish » Thu Jan 05, 2006 10:33 pm
had this problem now on two calibras and a cav gsi handbrake only working on offside?
turbo i wish
by Animal » Sat Jan 07, 2006 1:44 am
Mine also did the same, got it cleaned and adjusted and it works spot on now.
by lammy » Sat Jan 07, 2006 1:50 am
Yeah..mine has snapped on one side...MOT on 14/01 so i'm having the full cable replaced and hopefully that will do...try the cable first.
SE9
