V6 wiring ??
V6 wiring ??
Just put a v6 motor in to a corsa out of another corsa which was wrote off, didnt think to look at the wring b4 i ripped it out and now ive forgot what goes where, u guys probs know on my main ecu plug 3 bunch of wires come of it.... a green plug a purple plug and a black plug with 1 wire in it, and my fuel relay plug does any one know where these wires go on the v6 so i can locate or also know as bodge them in somewhere thanks guys ............
D_a-RR-e_N
This should tell you all you need to know.
<a href="http://www.v6calibra.com/" target="_blank">http://www.v6calibra.com/</a>
Take a look at this page:
<a href="http://www.v6calibra.com/motonic/v6calibra_motronic_faultcodes.htm" target="_blank">http://www.v6calibra.com/motonic/v6calibra..._faultcodes.htm</a>
About half way down there's a pinout diagram for the main ECU plug.
Trace the wires from the three plugs you mention back to the ECU and work out what they're for that way.
hoglabs
Halfway down the fault code page is a pinout diagram of the main ECU plug.
My suggestion is to use this and work out where the three connectors are supposed to connect to by tracing the wires back from the three connectors to the main ECU plug. Once you have worked this out you will know what they are supposed to connect to.
You could also try posting pics of the three connectors to see if anyone recognises them and where they are supposed to go to.
hoglabs
