koni ssk
koni ssk
My koni ssk ( yellow top adjastable ) suspension set came with these springs
<a href="http://www.lesjoforsab.com/default.asp" target="_blank">http://www.lesjoforsab.com/default.asp</a> ( sport spring kit - red )
Was wondering if they are any good or should I swap them for something else, did not realize I would get two different brands.
Molecule
the red ones are the ROC springs i believe,the vogtland are purple. but think koni have now switched to roc. they must be pretty gd i would have though for koni to include them in the pack, the vogtland ones are cracking springs,regal used to sell them.
<a href="http://cms.vogtland.com/ITmaxxDeluxe/bin/ITmaxxDeluxeServer.dll?Article?ID=279&Session=2-7PhahufA-1-91838200642011312&Via=Nav" target="_blank">http://cms.vogtland.com/ITmaxxDeluxe/bin/I...2011312&Via=Nav</a>
Welsh_Andy
Molecule
<!--QuoteBegin-Molecule+--><div class='quotetop'>(Molecule)</div><div class='quotemain'><!--QuoteEBegin-->thanks mate, was expecting an all koni kit.......duh. Will slap 'em on hopefully this weekend<!--QuoteEnd--></div><!--QuoteEEnd-->
you'll find that most companies only make the one component,like bilstein,koni make shocks then use other springs,same goes for most others too
Welsh_Andy
