5 stud conversion
5 stud conversion
by JAY69 » Mon Jan 16, 2006 1:52 pm
hi i own a 1996 calibra 20l 16v does anybody know what parts would i need to convert my 4 stud hubs to 5 stud so i can fit turbo wheels would i need to change discs + calipers thank you
JAY69
by ChrisP » Tue Jan 17, 2006 3:47 pm
Get some secondhand V6 or turbo front struts with brakes and discs, they will fit straight on (the discs and calipers are different from yours) For the back you need V6 arms as the abs sensors are in the wrong place on the turbos. The discs are the same size on the back but obviously have the wrong number of holes, calipers are the same though. Thats the easiest route anyway
Chris
ChrisP
by D_a-RR-e_N » Tue Jan 24, 2006 3:28 pm
or get them drilled to 4stud i did to put on my corsa cost me a tenner per disk to get drilled and fit spot on!
D_a-RR-e_N
by ealex » Tue Jan 24, 2006 3:50 pm
<!--QuoteBegin-D_a-RR-e_N+--><div class='quotetop'>(D_a-RR-e_N)</div><div class='quotemain'><!--QuoteEBegin-->or get them drilled to 4stud i did to put on my corsa cost me a tenner per disk to get drilled and fit spot on!<!--QuoteEnd--></div><!--QuoteEEnd-->
are you saying i could fit turbo calipers and discs to the front of a normal redtop, 4 stud? just by drilling the discs to 4 holes?
ealex
by ice man » Tue Jan 24, 2006 5:01 pm
Isn't the spiggot 56.6 on the 4 stud and 65 mm on the 5 stud models, surely the discs would be running out slightly radially which would vibrate and isn't ideal...
ice man
by red16V » Wed Jan 25, 2006 2:06 am
If you get in contact with LMF, they can provide you with a set of spacer rings to take it down to the correct size. Thik they cost me £15 + P&P, then already had a set of drilled & grooved turbo front discs, had them re-drilled to 4 stud. Painted the turbo calipers, then fitted & bled the braked. Be warned though, turbo or V6 brakes only fit behind 16" wheels, or cav gsi rims (came as standard on some calibras). They look rather nice & filling behind a set of 16" BBS RX alloys on a calibra ....:icon_mrgr
red16V
Users browsing this forum: Bing [Bot] and 7 guests
