Tyre wear
<!--QuoteBegin-Mac+--><div class='quotetop'>(Mac)</div><div class='quotemain'><!--QuoteEBegin-->Do you not have to replace both the bushes on each wishbone(four in all), or just the inside ones on both wishbones?
Are they for all models or just the 4x4's
Cheers.<!--QuoteEnd--></div><!--QuoteEEnd-->
its just the inside bushes,, i should know,, i got ripped off & paid £99 for 2 bushes,, i actually thought i was getting a full rear end bush kit for that money,,
dont worry,, i was not slow on taking the bushes back to the rip off merchants
joeraz
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->Well just come back from my tyre firm,had to lash out on 2 new tyre's for the back,£145,so think i will find out about these camber correction bushes.<!--QuoteEnd--></div><!--QuoteEEnd-->
i've ordered a couple from irmscher. i should be able to fit them before the essex meet so i'll let you kow how i get on. thats if you're still going of course.
[img]/smile.gif[/img]
davefly76
Cheers.<!--QuoteEnd--></div><!--QuoteEEnd-->Just the inside bush is OK for approx -30mm drop. If you have more then that then both bushes will be required to correct the camber.
If you want a cheap (but hard work) way of doing it then do a search for a post by Fatladz on a DIY camber correcting method. I thought it was a 'How to...' but can't find it.
daddycool
