camber correction
camber correction
could someone tell me what is replaced when fitting this kit? was looking at the regal site, 180......Is there any cheaper solution ( without pulling the car apart )? I will be lowering my car 35mm.
Molecule
The ones on the semi-trailing arms (wishbones) on the rear suspension. There's two main bushes per side.
Fat'z did a bit of home grown camber correction a while ago and posted up what he did. Would be worth doing a search to see what it brings up??
Just found it in the How-to section........
<a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=25" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=25</a>
TommyC
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->Ok,just ordered my powerflex bushes from Demon Tweeks as Powerflex dont sell direct,total for the back with p+p was £91.00,spoke to powerflex so i know im getting the correct ones.<!--QuoteEnd--></div><!--QuoteEEnd-->
Have you got a link?????
Fostersice17
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->I rang them direct sg-1,as i could not find the right one on the website,plus wanted to make sure i was getting the correct set,so rang both powerflex and demon tweeks,part number is PFR80-440MLK<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheers fella I will give them a bell. Are you going to fit it yourself??
I was gonna,but spoke to the guy who does some mechanical work on my car and he said it aint that easy job.He is gonna charge me £70 to do the lot,plus with the current weather i don't really fancy working outside.So i will let him do it,gotta get it done im going through 2 tyre's at the back every 5-6 months now.
Fostersice17
