ABS fault - HELP!!
ABS fault - HELP!!
by Doodley » Fri Jan 27, 2006 2:14 pm
I recently took my car 4 an mot, it failed because the ABS light is on. The ABS does not function, anybody know why? I have only recently bought the car, the owner had aftermarket alloys on it, but he took these off and put 14" corsa GSI wheels on. When i bout the car the ABS light was not on, any ideas why? is it possible that the smaller wheels couldve cut throu an ABS wheel sensor cable? The garage said it could cost up to £800 :eek: for them to fix if worst came to the worst. Any ideas anyone?!
Doodley
by houston » Fri Jan 27, 2006 2:22 pm
what year is it? you might be able to do a test on it, have a search for abs codes, cant see it being the wheels messing it up, most likely a speed sensor.
houston
by RobbieV » Fri Jan 27, 2006 2:23 pm
Hi and welcome to the site [img]/smile.gif[/img]
Have a look at this and see if it can help, if you need more help just shout.
<a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a>
by Doodley » Fri Jan 27, 2006 2:27 pm
its 1993 k plate, someone said it could be the relay,how do i go about the tests you mention?thanks for your help
Doodley
by Doodley » Fri Jan 27, 2006 2:29 pm
thanks that site is very helpful!
Doodley
by RobbieV » Fri Jan 27, 2006 2:29 pm
<!--QuoteBegin-Doodley+--><div class='quotetop'>(Doodley)</div><div class='quotemain'><!--QuoteEBegin-->its 1993 k plate, someone said it could be the relay,how do i go about the tests you mention?thanks for your help<!--QuoteEnd--></div><!--QuoteEEnd-->
All the info you need is on the link, just sit back and have a good read [img]/smile.gif[/img]
by Doodley » Fri Jan 27, 2006 3:17 pm
the fault code given is that the ABS ECU is fualty, I only have a cavalier handbook (have not had chance 2 buy calibra 1 yet) it says the ABS ECU is under the sill on the passenger side.is this the same for the calibra? I cannot find it!
Doodley
by RobbieV » Fri Jan 27, 2006 3:23 pm
It could be in the engine bay, black box next to ABS valve block.
*edit*
Just looked in manual
The control unit is located under a cover in the passenger sill, to the left-hand side of the seat.
by Doodley » Fri Jan 27, 2006 4:32 pm
u were right the first time, its next to the ABS valve block with the relays, i cleaned the connections & put it back together, the ABS light went out, then after about 5mins of driving it came back on again! Replace the ECU i guess?
Doodley
by RobbieV » Fri Jan 27, 2006 4:36 pm
I take it you did the paperclip test ? what fault codes are you getting ?
by Doodley » Fri Jan 27, 2006 4:42 pm
yeah i did! got code 55 - "faulty ABS ECU - defective check connections and power" before I replace it how can I check the power going to it?
Doodley
by Cozy » Fri Jan 27, 2006 4:46 pm
after you cleaned the connections etc did you leave the battery disconnected for 1/2 hour to 1 hour, that will clear the codes then if its still faulty then the eml should come back on, might be something to do with the abs sensors rather than the ecu maybe, not too sure though
Cozy
by RobbieV » Fri Jan 27, 2006 4:51 pm
<!--QuoteBegin-Doodley+--><div class='quotetop'>(Doodley)</div><div class='quotemain'><!--QuoteEBegin-->yeah i did! got code 55 - "faulty ABS ECU - defective check connections and power" before I replace it how can I check the power going to it?<!--QuoteEnd--></div><!--QuoteEEnd-->
Using a multimeter across the +/- i think
by Doodley » Fri Jan 27, 2006 4:55 pm
ok, no i did not leave it disconnected for that long, i will go try. thanks
Doodley
by Doodley » Fri Jan 27, 2006 7:04 pm
I have now had the battery disconnected for an hour, with the engine idling the abs light did not show, when I drove down the road it came back on again!anyone know what is the next step?cheers
Doodley
