KW Coilover Suspension
I'd like to buy a kit KW for my Calibra turbo restyling (year 1995), but I don't understand what is the right model....
There are 4 different codes, and this is write on KW website:
Coil over variant2 inox
Calibra strutdiameter 90334221/222 06/90-(A)
Calibra strutdiameter 90334223/224 06/90-(A)
Calibra strutdiameter 90334942/943 06/90-(A)
Calibra strutdiameter 90425656/657 06/90-(A)
<a href="http://www.kw-gmbh.de/en/30_Products/20_KW_Coilovers/40_Application_List/index.php?modell_1=Calibra&level=3&hersteller_1=OPEL&gruppe=all" target="_blank">http://www.kw-gmbh.de/en/30_Products/20_KW...OPEL&gruppe=all</a>
I can't find these number on my (old) EPC
Can anyone help me ?
jackb77
1200,00€ good price?!! they are very expensive...
FK Coilovers have this tabel:
Calibra with ABS 45-80 mm 1,4 FKOP773 849,00 1,4,9 FKKKOP773 1049,00 - -
(diameter of front wheelbearing 66mm)
Calibra without ABS 45-80 mm 1,3 FKOP774 849,00 1,3,9 FKKKOP774 1049,00 - -
Calibra with ABS 45-80 mm 1,4 FKOP775 849,00 1,4,9 FKKKOP775 1049,00 - -
(diameter of front wheelbearing 72mm)
Calibra without ABS 45-80 mm 1,3 FKOP776 849,00 1,3,9 FKKKOP776 1049,00 - -
Calibra with ABS 45-80 mm 1,4 FKOP791 849,00 1,4,9 FKKKOP791 1049,00 - -
(diameter of front wheelbearing 74mm)
Calibra with ABS 45-80 mm 2,4 FKOP792 849,00 2,4,9 FKKKOP792 1049,00 - -
Calibra without ABS 45-80 mm 2,3 FKOP793 849,00 2,3,9 FKKKOP793 1049,00 - -
Calibra with ABS 45-80 mm 2,4 FKOP794 849,00 2,4,9 FKKKOP794 1049,00 - -
Calibra without ABS 45-80 mm 2,3 FKOP795 849,00 2,3,9 FKKKOP795 1049,00 - -
Calibra with ABS 45-80 mm 2,4 FKOP796 849,00 2,4,9 FKKKOP796 1049,00 - -
<a href="http://www.fk-automotive.com/data01/en/downloads/pdf_katalog/fk_2005_page_037-039.pdf" target="_blank">http://www.fk-automotive.com/data01/en/dow...age_037-039.pdf</a>
So there is a difference betwen Calibra version???
jackb77
So basically KW have different part no's for left and right hand struts, for cars with or without ABS to fit three different sizes of wheel bearing.
I'd check, using your chassis number, with your EPC (if it'll do it) or with a main dealer what size wheel bearings you have.
I'd assume they would be 74mm because it's a late Turbo, but you'd have to check to be absolutely sure!!!!
TommyC
<!--QuoteBegin-jackb77+--><div class='quotetop'>(jackb77)</div><div class='quotemain'><!--QuoteEBegin-->1200,00€ good price?!! they are very expensive...<!--QuoteEnd--></div><!--QuoteEEnd-->
thought they were only around £600, bout 900 euros. thats what i seen in an advert in TV.may be wrong though
Welsh_Andy
Easier to see if you group them together like this:-
Without ABS
With ABS
I would imagine you can break down their number system like this
1,3 FKOP774
side (left or right):- 1
No ABS :- 3
part no:- FKOP774
But thats only me guessing how to interpret it........
Without ABS
With ABS
1,3 FKOP774
No ABS :- 3
part no:- FKOP774
TommyC
