temp gauge on speedo not working..
by garymc » Sun Feb 12, 2006 3:41 pm
car temp gauge doesnt seem to move anymore, staying at 0 degrees, was fine until i was under the bonnet clipping back in some loose hoses. any idea what i could have done? thanks
garymc
by Leigh » Sun Feb 12, 2006 3:45 pm
Check the little spade connector on the side of the engine, it can fall off or snap ...
Mine came off a couple of years ago as it was loose, I just gently bent the 'prongs' in a little and it's been fine since..
Leigh
by garymc » Sun Feb 12, 2006 3:48 pm
infact, i noticed a wire coming out from near the air meter with a spade connector , but couldnt see where it should be pluged into
garymc
by debairaclijr » Sun Feb 12, 2006 4:11 pm
Mine does it all the time too, the connection is on the side of the engine (small mushroom nipple kinda thing). Give it a good clean as well.
debairaclijr
