rims on cally T .... offset help!!
by CAL.16V » Mon Feb 20, 2006 10:11 am
hi looking at getting a set of rims for my 4x4 cally turbo...
they are used.....
the question basically is... will they fit my car??
specs...
18" by 7.5" ..
tyres
215/35/18
offset
+52
i know they will fit but the worrying thing is the offset.. i know that the stock one is +49 and these rims are wider by an inch ... i know you can have around 40 offset but what about a 52 offset??
please help as they are really cheap and i can get these drilled to my stud pattern... cant find cheaper rims here.. so need to know if they are a go or not..
uess i could always fit spacers no???
CAL.16V
by CAL.16V » Mon Feb 20, 2006 10:12 am
<a href="http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=8037913604&fromMakeTrack=true" target="_blank">http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...mMakeTrack=true</a>
CAL.16V
by ealex » Mon Feb 20, 2006 3:04 pm
the pcd is wrong. those have the wrong distance between the studs, although they are in 5 stud. a greater et offset is not a problem, u can get spacers for that, but pcd is harder to change
ealex
by bodgetastic » Mon Feb 20, 2006 3:10 pm
I dont see a big problem with that offset and 18 x 7.5 with 215/35/18 is fine but the PCD is 5 x 114 which I dont see how you will be able to drill to suit as the holes would surely overlap ?!
by CAL.16V » Mon Feb 20, 2006 3:49 pm
been to a few wheel suppliers here in aus and that is the only pcd they have said they wpould drill for me ...
it is probably the most popular 5 stud pcd too... the redrilling would be in between each of the current holes and a little closer to centre of the wheel....
a few cally guys have it done here in aus as the 5x100 pcd is basically extinct bar 2-3 wheel types
so anywyas had a look underneath the car and the front tyre is really close to the struts so yous sure this would be ok??
worst comes to worse can i use something like this?
<a href="http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=4612572458&ssPageName=STRK:MEWA:IT" target="_blank">http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MEWA:IT</a>
only worried about how i would get the wheel on with them as we got bolts not wheel nuts and also wondering if i would need longer custom wheel bolts say for a 5 or 8mm spacer?
CAL.16V
by CAL.16V » Mon Feb 20, 2006 3:51 pm
anyone wanna do a very quick pjhotoshop for me on a dark coloured calibra?
CAL.16V
by RobbieV » Mon Feb 20, 2006 4:33 pm
Hi, +52 ofset will bring it very close to the hub, you will need spacers and the 5 stud pattern is 5x110 [img]/smile.gif[/img]
by daddycool » Mon Feb 20, 2006 6:15 pm
Do you know if the tyres have been rotated properly and are all same manufacturer?
If not then you will need to run in 2WD or get a new set of tyres.
daddycool
by CAL.16V » Mon Feb 20, 2006 10:32 pm
yeah rotated properly and same man...
once again i know the pcd is 5x110... gotta get them redrilled...
not sure if i will get them now becasue of the whole spacer issue
CAL.16V
by RobbieV » Mon Feb 20, 2006 10:48 pm
<!--QuoteBegin-CAL.16V+--><div class='quotetop'>(CAL.16V)</div><div class='quotemain'><!--QuoteEBegin-->once again i know the pcd is 5x110... gotta get them redrilled...<!--QuoteEnd--></div><!--QuoteEEnd-->
So whats this 5x100 you mentioned ?
by CAL.16V » Tue Feb 21, 2006 4:13 am
5x110 is my pcd and 5 x 114.3 is the wheels pcd which i can get redrilled
dont think i will get them now as cant check them out before auction closes
CAL.16V
