Indicator / Hazzards come on but dont flash
by Star_Silver_XE » Sun Feb 26, 2006 11:35 pm
Hi Guys,
I just recently purchased a cally and I had to change the battery. I now have a problem with the hazzard and indicator lights. They come on but do not flash. I've checked the fuses and they seem fine. I've been told to check the relay but I'm not sure which relay it is, Can anyone help?
Star_Silver_XE
by RobbieV » Sun Feb 26, 2006 11:39 pm
Hi and welcome [img]/smile.gif[/img]
Here's a list of fuses and relays to get you started with your problem -
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a>
by Star_Silver_XE » Sun Feb 26, 2006 11:47 pm
Thanks, this should help. If it is the relay are they expensive to replace?
Star_Silver_XE
by RobbieV » Sun Feb 26, 2006 11:56 pm
<!--QuoteBegin-Star_Silver_XE+--><div class='quotetop'>(Star_Silver_XE)</div><div class='quotemain'><!--QuoteEBegin-->Thanks, this should help. If it is the relay are they expensive to replace?<!--QuoteEnd--></div><!--QuoteEEnd-->
Nah dont think so [img]/smile.gif[/img]
by MarkV6 » Mon Feb 27, 2006 4:32 am
Check the hazard switch itself as well.
Put your hazard's on then pull on the switch. You should feel a 'click' then turn them off and try the indicators.
If that cures it then your switch is going kaput......
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by IRISHD » Wed Mar 01, 2006 5:49 pm
Had the same problem a couple of weeks ago.Narrowed the problem down to the hazard warning switch or the relay. Cause I was going into work I took the battery cables off to stop the battery running down. Checked ebay and found both for only a few quid but when I went back to the car it had sorted itself out
IRISHD
