Wishbone bolts
Wishbone bolts
Just spent 2 days trying to change one bloody wishbone. The first day I didn't have the right size spanner, so had to cancel, but only after I'd got the car jacked up, wheel off, broke the ball joint etc.
I bought the spanner, but then couldn't for the life of me get the horizontal bolt undone. Had to get the RAC to come out as I couldn't leave the car where it was. RAC loosened the bolt, but buggered off sharpish after breaking my ratchet and not telling me.
The bolt was almost rounded off, since it was the horizontal one where access is difficult, I switched the bolts over 'cos I thought it'd be easier to do it up vertically. Couldn't tighten the thing all the way 'cos of it being rounded, but I couldn't tighten the horizontal one all the way either. Just phoned Vauxhall to order a new bolt, and they've told me these bolts are different. Though they looked the same to me. One under £2 and the other was over £3. Parts bloke says they both have the same size code. Anyone know if these are actually different? I'm hoping I haven't buggered up the thread or anything.
Not sure if I'm going to do the other wishbone myself after all the hassle. Something just seems to go wrong everytime I touch a ratchet. Just phoned up a few mechanics though, all of whom tried to rip me off. One guy said 2 1/2 hours labour for one wishbone.
Anybody get any tips for getting stubborn bolts off? Just incase I get the motivation to go out and do the other side.
Cheers,
Dan
Cheers,
Dan
dan1w
you really do need a 28 inch breaker bar and some 6 point heavy duty sockets, a ratchet just will not take that sort of strain...and your going to be lucky using a spanner
<a href="http://www.honest-johns.co.uk/index.php?product_id=105101&option=Prod_detail&image_id=38343" target="_blank">like this </a>
I only used a spanner for the ball joint, since a socket won't fit in there. Wasn't a problem. I used a breaker bar, but it didn't help, didn't use 6 point sockets, would that make a big difference? The main problem seemed to be that the bolt wasn't deep enough and whenever I managed to get some resistance the socket would just slip off, eventually rounding the bolt off.
dan1w
go down the local scrappy and get bolts off an astra or something they r all the same or i can send u one as i have some spares if u send me a sae with stamps to cover postage
as for the bolts i'm doing mine now but replacing the ball joints too (great fun with the grinder) if u aint got a breaker bar use 2x spanners for leverage
the bolts are 15/16 and the front is 17 iirc
tobys73
<!--QuoteBegin-dannypacu+--><div class='quotetop'>(dannypacu)</div><div class='quotemain'><!--QuoteEBegin-->i did my wish bones and anti roll roll links had no probs with a socket and ratchet
having said that mine are snap on<!--QuoteEnd--></div><!--QuoteEEnd-->
and so are mine, but much better to crack them first with the breaker bar (hence the name)[img]/smile.gif[/img]
and not everyone is going to have snap on tools
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->you really do need a 28 inch breaker bar and some 6 point heavy duty sockets, a ratchet just will not take that sort of strain...and your going to be lucky using a spanner<!--QuoteEnd--></div><!--QuoteEEnd-->
I agree, I used one on my Astra. Took about 30 mins per side including Tea breaks.
I was wondering why go to the bother of fitting new ball joints when a whole wishbone inc bushes and balljoint is only about £25. A lot less hassle fitting them too.
It only gets difficult if you are fitting Poly bushes in them, took me 7 hours a side as i couldnt get them in the holes due to the non flexiness of the poly bushes.
C411BRA
<!--QuoteBegin-C411BRA+--><div class='quotetop'>(C411BRA)</div><div class='quotemain'><!--QuoteEBegin-->I was wondering why go to the bother of fitting new ball joints when a whole wishbone inc bushes and balljoint is only about £25. A lot less hassle fitting them too.<!--QuoteEnd--></div><!--QuoteEEnd-->
very true....they are cheap enough!
i have removed the whole engine and subframe without a breaker bar though.....
T.F.S.
<!--QuoteBegin-C411BRA+--><div class='quotetop'>(C411BRA)</div><div class='quotemain'><!--QuoteEBegin-->I agree, I used one on my Astra. Took about 30 mins per side including Tea breaks.
It only gets difficult if you are fitting Poly bushes in them, took me 7 hours a side as i couldnt get them in the holes due to the non flexiness of the poly bushes.<!--QuoteEnd--></div><!--QuoteEEnd-->
know what u mean with locatig the holes
as for the ball joints its not the money its the satisfaction of doing them yourself [img]/smile.gif[/img]
so far i done everything myself- engine bodywork, suspension, kit etc and if i can find a good location i wil try and paint it too, though it will be harder cause its pearl [img]/sad.gif[/img]
tobys73
