alarm
alarm
by metal-ste » Mon Feb 27, 2006 4:20 pm
hi all.recently got a v6 and all's good except for the alarm which does'nt seem to be workin.the interior sensor's r there and the red led on the dash is there 2,but when i deadlock the car the alarm does'nt arm.any ideas?thanks for any help
metal-ste
by Cozy » Mon Feb 27, 2006 4:25 pm
have you got a fob for the alarm and does it lock the car when you click it, usually these will lock the car then deadlocking is done after that with the key on its own, you should have a seperate fob for the alarm
Cozy
by RobbieV » Mon Feb 27, 2006 4:34 pm
Standard calibra alarms dont have key fobs, its all done on the drivers key [img]/smile.gif[/img]
by Cozy » Mon Feb 27, 2006 4:38 pm
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->Standard calibra alarms dont have key fobs, its all done on the drivers key [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
ahha i have an aftermarket on mine then,
ste, how do you know the alarm isn;t arming
Cozy
by C411BRA » Mon Feb 27, 2006 5:06 pm
I also got an LED on the dash by the headlight switch. It dont seem to do anything tho. The one in the interior sensor flashes for a minute at about twice a second when I deadlock the car then flickers every few seconds after that. Not sure if the ultrasonics work tho. But I can set off the alarm by opening the boot, so something is working.
Any way to self test it?
C411BRA
by RobbieV » Mon Feb 27, 2006 5:08 pm
<!--QuoteBegin-C411BRA+--><div class='quotetop'>(C411BRA)</div><div class='quotemain'><!--QuoteEBegin-->I also got an LED on the dash by the headlight switch. It dont seem to do anything tho. The one in the interior sensor flashes for a minute at about twice a second when I deadlock the car then flickers every few seconds after that. Not sure if the ultrasonics work tho. But I can set off the alarm by opening the boot, so something is working.
Any way to self test it?<!--QuoteEnd--></div><!--QuoteEEnd-->
Some info on the standard alarm
<a href="http://www.v6calibra.com/alarm/v6calibra_atas.htm" target="_blank">http://www.v6calibra.com/alarm/v6calibra_atas.htm</a>
by RobbieV » Mon Feb 27, 2006 5:18 pm
Self testing standard alarm -[img]/smile.gif[/img]
by C411BRA » Mon Feb 27, 2006 5:25 pm
Thanx, gonna nip out and do it now while the boss is away.
C411BRA
by metal-ste » Mon Feb 27, 2006 6:16 pm
i had a redtop with with a key fob and that locked the doors and set the alarm-the led then starts to flash.with my v6 the doors deadlock but the led does'nt flash so im thinkin the alarm's not workin?im goin to check that led on the diagram that robbie posted to see if that one's doin anythin-hope it is as i've told my insurance that the cars got a workin alarm-oops
metal-ste
by TonyDTM » Mon Feb 27, 2006 7:46 pm
Easy way to check if the factory fit alarm is working is to pop the bonnet. Deadlock the vehicle, wait 20 seconds for arm. Goto the front of the car, lift the bonnet up, keep your ears away from the alarm hooter.
If it works you'll know about it.
Anything else, key fobs etc are non-factory fit. If you have one and it aint working, you need to know the make of it, and where it was fitted to be able to do anything about it. Unless its a VX aftermarket, it wont deadlock your doors.
Most times it pays to get another and rip out the old stuff, and start afresh
TonyDTM
by metal-ste » Mon Feb 27, 2006 9:38 pm
thanks for that Tony,give that a try sometime tomorrow.
metal-ste
by calibra_v6_dtm » Tue Feb 28, 2006 2:15 am
my 1994 V6 has the immbiliser and remote locking (think its a bosch system) factory fitted, there is also the factory key based alarm with ultrasonics, none of it seems to work so i'm prob gonna rip it out an put a clifford in
calibra_v6_dtm
by dj_smurph » Wed Mar 01, 2006 10:23 am
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Unless its a VX aftermarket, it wont deadlock your doors.<!--QuoteEnd--></div><!--QuoteEEnd--> my brand new toad alarm seems to do a very good job at deadlocking but then i do think it interfaces with the central locking.
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->so i'm prob gonna rip it out an put a clifford in<!--QuoteEnd--></div><!--QuoteEEnd-->
i had a clifford before never had a days problem but just before christmas a few calibras got nicked on here and the common factor was clifford iirc, put the toad on AI606 with prox sensors for £300
dj_smurph
by MR_TOAD » Thu Mar 02, 2006 4:56 pm
<!--QuoteBegin-dj_smurph+--><div class='quotetop'>(dj_smurph)</div><div class='quotemain'><!--QuoteEBegin-->my brand new toad alarm seems to do a very good job at deadlocking but then i do think it interfaces with the central locking.
i had a clifford before never had a days problem but just before christmas a few calibras got nicked on here and the common factor was clifford iirc, put the toad on AI606 with prox sensors for £300<!--QuoteEnd--></div><!--QuoteEEnd-->
Toads the one to go for now since Clifford got bought out
I fit the AI606 plus proximity for £280 so thats not a bad price
Ian
MR_TOAD
by metal-ste » Fri Mar 03, 2006 10:17 pm
my factory fit alarm defo isn't workin.add it to the list of other things i need to sort out!
metal-ste
