Another brake question
Got some discs today and they turned out to be wrong because they had the bearing bit inside. But the only others they say there is are 270mm. They are 4 stud but they say they are 4wd discs.
I have a 2.0 16v ecotec.
Any ideas?
Any ideas?
<!--QuoteBegin-Animal+--><div class='quotetop'>(Animal)</div><div class='quotemain'><!--QuoteEBegin-->Got some discs today and they turned out to be wrong because they had the bearing bit inside. But the only others they say there is are 270mm. They are 4 stud but they say they are 4wd discs.
Any ideas?<!--QuoteEnd--></div><!--QuoteEEnd-->
Bearing bit inside ? whats that then ?
The disc wasn't hollow it had like a tube running down the centre that holds bearings.
Also where as the one that is is flat like this ]
The one I got had a lip on it, kind of like it would look like if it was on the car. Something like this }
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Calibra 2.0i 16v 90-98 rear
<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Solid - Mountings 4
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Disc diameter 270.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Disc thickness 10.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Overall height 77.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Centre diameter 57.0mm
<!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->Minimum thickness 8.0mm
<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec-->
nigw
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Calibra 2.0i 16v Turbo 4x4 4/92-96
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->[/font]
[font=Arial]<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Solid - Mountings 5 *****
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Centre diameter 65.5mm ******
nigw
Users browsing this forum: Majestic-12 [Bot] and 33 guests
