Lowered 40mm, best way to stop scrubbing?
<!--QuoteBegin-Tyke+--><div class='quotetop'>(Tyke)</div><div class='quotemain'><!--QuoteEBegin-->Well I went for the spring assistors as a quick solution, they turned up this morning and I had them fitted in the rain within 5 minutes.<!--QuoteEnd--></div><!--QuoteEEnd--> Are they the rubber type that slip between the coils, or the bolt together brackety things? Both from Grayston i think.
C411BRA
<!--QuoteBegin-C411BRA+--><div class='quotetop'>(C411BRA)</div><div class='quotemain'><!--QuoteEBegin-->Are they the rubber type that slip between the coils, or the bolt together brackety things? Both from Grayston i think.<!--QuoteEnd--></div><!--QuoteEEnd-->
Rubber type, I boiled them for 10 mins as stated in instructions to soften them, and they went straight in.
Tyke
