Front wheels rubbing!... Help?
by Johnny » Sat Mar 18, 2006 4:44 pm
i've fitted an Apex 30mm suspension kit, the rides a bit rough, which was expected, but under medium/harsh cornering the front wheels rub on the arches, i've got 205,40,17 tyres but i'm not sure of the offset.... Any Ideas??? [img]/smile.gif[/img]
Johnny
by dj_smurph » Sat Mar 18, 2006 7:26 pm
shocks and springs or just springs/have you checked all the drop links
dj_smurph
by Johnny » Sun Mar 19, 2006 1:07 pm
shocks and springs, what are drop links??? [img]/smile.gif[/img]
Johnny
by Dan Willis » Sun Mar 19, 2006 2:39 pm
You need to check the offset of your wheels - they could be the cause.
Dan
by Sg-1 » Mon Mar 20, 2006 9:44 am
Yeah, it sounds like the off set. Mine has been dropped 40 mm with 18's and I have no problem.
by Phantom » Wed Mar 29, 2006 2:16 am
to answer your question drop links are the ends of the anti-roll bar which fit into the lower suspension arms, often the bolt shears and you have no anti-roll, this should make a noise however when you corner
Phantom
