no brakes ...please help
by blue_v6 » Sun Mar 26, 2006 6:18 pm
hello guys could anyone help me i just change the brake discs the calipers and the calipers support into my v6 cali i just put cali turbo ones and after change everything,i got to bleed them done but still the pedal its soft and no brakes at all,anyone could help me any sugestions?
thanks
blue_v6
by Stupink » Sun Mar 26, 2006 6:42 pm
Keep on bleeding.
Do the fronts first, passenger side preferably, then the rears.
If its still soft, then look for the leak, cos its either got to be air in the system or a leaky system.
by blue_v6 » Mon Mar 27, 2006 9:12 pm
ok found the problem,the caliper cilinders was gone, now i got pedal but when i travel and brake this knocking noise comes out of nowhere and the pedal get spongy,we presurized the master cilinder but holds the fluid pressure,only on travel the pedal gets spongy and a funny noise like a knocking......
please anyone can help...........thanks
blue_v6
by Stupink » Mon Mar 27, 2006 9:19 pm
sounds like the abs kicking in strangely? try with the abs dissabled see how it feels? (not sure if theres a fuse for it, if not just unplug one of the front roadwheel speed sensors from the arch).
by blue_v6 » Mon Mar 27, 2006 9:29 pm
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->sounds like the abs kicking in strangely? try with the abs dissabled see how it feels? (not sure if theres a fuse for it, if not just unplug one of the front roadwheel speed sensors from the arch).<!--QuoteEnd--></div><!--QuoteEEnd-->
:thumb: thanks Stu i will try that and post a replay to see how it is.......
blue_v6
by Peachperformance » Mon Mar 27, 2006 9:37 pm
Aslo make sue your spring retainers for the calipers are on correctly. If they're sat in front of the lip instead of behind it they will push the caliper sideways. Then when you brake the caliper starts kicking and can be heard as a knocking noise. It also pushes the pads off the disc and causes a spongy pedal.
Peachperformance
by blue_v6 » Tue Apr 18, 2006 7:37 pm
problem still not solved yet still making that funny knoking noise,checked the front ABS sensors had a ABS reading fault nothing i looked for any leaks or any cracks on the pipes nothing,i was wondering if is any of the front cilinder on the calipers,got some from a veccie but too short,i really dont have a ideea whats wrong.....:mad:
blue_v6
