pedal travel???
pedal travel???
as the title suggests really how much pedal travel do you have on the brakes. since driving the f****a to work i have noticed that the brakes kick in way before the callys. is this right? if not why not???
chief
apart from beefing up your hoses, use could always change the brake fluid on regular intervals. I do a main service once a year on mine and change the oil twice a year. Brake fluid loses its hydraulic properties over time and therefore is every bit as important as oil changes. Many people overlook this. It only takes 15 mins with an old milk bottle and a bit of old washer tubing.
TonyDTM
easiest way is a bit of wire around the neck of a milk bottle. put a piece of washer tube on the brake bleed nipple. put the other end in the bottle, undo the bleed nipple a couple of turns, hang the lot on the caliper using the wire. pump the pedal til it runs dry. tighten the nipple. do the next one.
when all are done, loosen the 1st again, tip in brake fluid. get someone to watch while u pump the pedal, as soon as u get 1 good squirt come out the tube, tighen the nipple. Do the rest the same.
TonyDTM
I've got braided hoses and new fluid.
However it still feels pathetic compared the brand new Passat I was driving the other week.
I think the Cally's brakes are generally crap. I can't help thinking there's something wrong with my set-up, but there can't be. It's got new discs and pads all round, braided hoses, and new fluid. It never loses fluid, so I'm assuming there's no leakage anywhere.
However, when first driving the car if I give the pedal a couple of pumps before the first proper brake, it makes it feel firmer. Is this normal???
On top of that, in general I think it's just an old design thats not up the task of 1400kg and 260 Bhp.
Paul
Users browsing this forum: Majestic-12 [Bot] and 23 guests
