what brake dics
what brake dics
whos got what on there cars out there? any comments, good and bad on current and past products appreciated...
ecosseM
<!--QuoteBegin-ecosseM+--><div class='quotetop'>(ecosseM)</div><div class='quotemain'><!--QuoteEBegin-->whos got what on there cars out there? any comments, good and bad on current and past products appreciated...<!--QuoteEnd--></div><!--QuoteEEnd-->
EBC / green stuff, red stuff, new yellow stuff... all have pretty good reviews. The EBC discs for the cally are drilled (stopped holes, not all the way thru) and grooved front and rear. Some ppl are advertising on Egay for silly money.
Personally i run mine on totally standard VX parts. N/S front pads started to squeal after 600 miles and rear O/S shoe squeaks every time the handbrake is applied.
I will be changing the whole lot by June or ealier if money allows.
TonyDTM
Got front/rear grooved discs from this chap -
<a href="http://stores.ebay.co.uk/sportbrakediscs_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm" target="_blank">http://stores.ebay.co.uk/sportbrakediscs_W...sQ3amesstQQtZkm</a>
He can do them drilled and grooved or just drilled or like mine just grooved, good prices and ive not had any problems with them [img]/smile.gif[/img]
I've just fitted Red Dot 308mm 20 groove discs and they seem to work well.
I've just fitted Tarox 6 pots and 300mm 60 groove discs and predator pads up front and am getting some Skyline GT32R 4 pots modified to fit the back with black diamond drilled and groove discs, hopefully it will be spot on. I was running the Hi Spec 4 pots with 300mk drilled and grooved discs with greenstuff pads up front and they were great, I just wanted something REALLY good.
imcsherry
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->Got front/rear grooved discs from this chap -
He can do them drilled and grooved or just drilled or like mine just grooved, good prices and ive not had any problems with them [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
One thing iv noticed with them.... some of the groved disks, the grove dosent go all the way to the edge of the disk. Isnt this needed to let the dust/heat escape? meaning as the pad is passing over the grove there will be a build up of dust / heat that gets trapped in the grove with nowhere to escape....?
or is that just rubbish [img]/rolleyes.gif[/img]
Add_Gee
Users browsing this forum: Majestic-12 [Bot] and 34 guests
