removing pins from connector block?
by johnny_adidas » Sun Apr 09, 2006 1:14 pm
is it possible to remove the female pins from a connector block or do you just have to cut the cables and fit new females then move it to another plastic block.
the connector block type im on about is the 9-pin type, in my case the hazard switch female block. i need to move the cables from this to another black plastic block which suits the new position for my hazard switch better.
ive removed the yellow retaining clip from the block but the wires and females pins still wont pull out of the block. ideas?
johnny_adidas
by FatLadZ » Sun Apr 09, 2006 2:46 pm
doesnt the hazard light switch just pull out of it?
is there a black pin that goes through it?
FatLadZ
by johnny_adidas » Sun Apr 09, 2006 5:45 pm
ya the hazard switch pulls out,its the black plastic block thats behind that though that the wires are held into by metal pins. need to move these pins to another plastic block. (theres a double block over on the right hand side of the steering wheel where i need the hazard light moved to. one side of the double block is the headlight adjuster, other one block is free. so just makes sense to move the pins to this as the double block is held firmly in this position)
johnny_adidas
by johnny_adidas » Mon Apr 10, 2006 2:22 pm
anyone? need to get this sorted before i can put my steering wheel back on.
johnny_adidas
by Fraz » Mon Apr 10, 2006 2:56 pm
yes you can remove the pins, just need a very small thin screwdriver or a needle ...and then you push it in from the front IIRc and you push down the small lock tab thats on the blade of the pin ..dont forget to push the tab up again before you put it back in
by johnny_adidas » Mon Apr 10, 2006 3:08 pm
tanx for the reply fraz. looking at the plastic block from the front. there is a plus sign "+" shape to the hole. the male pin on the hazard switch itself is a slot shape "|" and fits into the female pin which is a double slot say "||" so there is space either side. i tried pushed sumthin down either side of the female pin to squeeze it as such but it didnt seem to budge, i tried this fairly hard but didnt wana pull the cable outa the pin. this what u mean?
johnny_adidas
by johnny_adidas » Mon Apr 10, 2006 3:18 pm
think i got u now. IIRC if u look at the female pin from the front its more like a C shape than || so just bend down the side wit the slot in it and it shud pull out?
johnny_adidas
FRAZ, public thank you!!!
by johnny_adidas » Tue Apr 11, 2006 9:36 am
and a personal one also. thanks a million!!
the little clip is on the back side of the c as i called it and just shoving it in with a screwdriver released them. i now have my hazard switch moved and my dash back together. thank you very much!!!!
johnny_adidas
