Mystery lead/sensor
Mystery lead/sensor
by dan1w » Mon Apr 10, 2006 7:57 pm
Today I found a lead in the engine bay with frayed wires that probably needs replacing, but I don't know what it is.
It was hanging under the engine bay behind the passenger side headlight/battery. It has one of those connectors that you squeeze 2 sides to get off followed by a black lead and then what must be a sensor which is a clear bullet shaped piece of plastic with a white piece of plastic visible in the middle of it. It has a green and a brown wire going into it which you can also see through the transparent plastic 'bullet'. The wiring led back to the cab.
Hopefully someone knows what this is before I have to get the digital camera out.
Cheers,
Dan
dan1w
by ecosseM » Mon Apr 10, 2006 8:10 pm
would have to say, post a pic of it to get more help, and what engine etc
ecosseM
by Johnnytenpints » Tue Apr 11, 2006 12:02 am
:iagree: A picture would help. Does the cable run down to the bumper?
Johnnytenpints
by EY » Tue Apr 11, 2006 12:08 pm
Outside temperature sensor? Try unpluging it and see if you get an F on the trip computer.
by johnny_adidas » Tue Apr 11, 2006 12:40 pm
the outside temp sensor is located by the passenger headlight, its black and does have a black cable also. pics wud help alrite
johnny_adidas
by dan1w » Tue Apr 11, 2006 3:37 pm
I originally thought it was the temp sensor as I've had an F on the trip computer since I've had the car and the wires on this lead are chopped to crap from being dragged along the road, but then thought the temp sensor would surely not be so close to the engine. So I suppose this is supposed to sit in the bumper somewhere?
Here's a pic just to make sure. Not great quality as my camera won't focus.
Cheers,
Dan
dan1w
by Rusty_CallyT » Tue Apr 11, 2006 4:13 pm
both your indicator repeaters on the wings working ok?
Rusty_CallyT
by Animal » Tue Apr 11, 2006 4:57 pm
I aint come across one of those before. Looks a little like an led (shape wise) but I don't think it is.
by dan1w » Tue Apr 11, 2006 4:59 pm
Way too big for an LED. Pretty sure my indicators work, but I will run out and check that later. It's not a bulb if that's what you're wondering.
dan1w
by Rusty_CallyT » Tue Apr 11, 2006 5:07 pm
<!--QuoteBegin-dan1w+--><div class='quotetop'>(dan1w)</div><div class='quotemain'><!--QuoteEBegin-->Way too big for an LED.<!--QuoteEnd--></div><!--QuoteEEnd-->
how big is it?
u can get some huge LED's...
worth checking the winkers on the wings. [img]/wink.gif[/img]
Rusty_CallyT
by Tim2001 » Tue Apr 11, 2006 5:13 pm
brake pad wear sensor for the wiring and the connector block and the double thickness piece in the middle of the wiring not sure about the end though
Tim2001
by Rusty_CallyT » Tue Apr 11, 2006 5:17 pm
that plugs in down by the wheel tho, wasnt this connected somewhere in the bay?
Rusty_CallyT
by dan1w » Tue Apr 11, 2006 5:38 pm
It isn't the brake pad wear sensor. Yeah it was coming out of the loom from the cab, down the right side of the battery behind the headlight and then hanging down to the floor.
dan1w
by Doodley » Tue Apr 11, 2006 6:00 pm
is ur car alarmed? if it is does the alarm work? looks to me a bit like a shock sensor
Doodley
by dan1w » Tue Apr 11, 2006 6:04 pm
It isn't alarmed, no.
Cheers for the replies so far, hopefully I'll get to the bottom of it.
dan1w
