Mystery lead/sensor
by Rusty_CallyT » Tue Apr 11, 2006 6:09 pm
tested the winkers yet?
Rusty_CallyT
by TonyDTM » Tue Apr 11, 2006 6:18 pm
speed sensor for the ABS?
TonyDTM
by dan1w » Tue Apr 11, 2006 6:20 pm
Indicators working. ABS is also working.
dan1w
by Rusty_CallyT » Tue Apr 11, 2006 6:25 pm
got a shot of the place where it actually plugs in?
Rusty_CallyT
by dan1w » Tue Apr 11, 2006 11:00 pm
Here's where it plugs in
dan1w
by TonyDTM » Tue Apr 11, 2006 11:13 pm
wtf...
i'll have to have a gander @ mine tomorrow.
TonyDTM
by dan1w » Tue Apr 11, 2006 11:59 pm
aha, it seems I do have a factory fitted alarm I had no idea about. I looked through the security manual and realised I didn't know the procedure for deadlocking, so I deadlocked and looked for the red flashing light. Tested it by popping the bonnet and deadlocking to find it set the hazards off but not the horn. Yet another problem to tackle.
Doesn't help with the mystery lead problem though as the diagram of the alarm here ( <a href="http://www.v6calibra.com/alarm/v6calibra_atas.htm" target="_blank">http://www.v6calibra.com/alarm/v6calibra_atas.htm</a> ) shows nothing like it under the bonnet.
Anyone know where the pins mentioned on the above site can be found to get a fault code?
dan1w
by Rusty_CallyT » Wed Apr 12, 2006 12:18 am
dont think it'll be alarm related.
i dont remember anything like that in my bay at all... weird
what year and model is it?
Rusty_CallyT
by Rusty_CallyT » Wed Apr 12, 2006 12:24 am
check the oil level sender on the front of the sump, might have been ripped apart and be part of that
Rusty_CallyT
by Fraz » Wed Apr 12, 2006 12:26 am
I would say what you have there is the remains of the temp sensor that should be in your bumper
by dan1w » Wed Apr 12, 2006 12:27 am
Sorry, should have mentioned that. It's a K reg 16v
dan1w
by Fraz » Wed Apr 12, 2006 12:28 am
or is your car fitted with headlamp washer jets?
by Rusty_CallyT » Wed Apr 12, 2006 12:32 am
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->I would say what you have there is the remains of the temp sensor that should be in your bumper<!--QuoteEnd--></div><!--QuoteEEnd-->
its the wrong connection for that mate
Rusty_CallyT
by dan1w » Wed Apr 12, 2006 12:32 am
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->or is your car fitted with headlamp washer jets?<!--QuoteEnd--></div><!--QuoteEEnd-->
It is, yeah. Can't see how this would be anything to do with them though 'cos the wires at the end are incased in plastic.
dan1w
by Fraz » Wed Apr 12, 2006 12:45 am
just the location of where the end plugs in ..was just a thought (do they work your washers?) as for the end could it not be someone has cut pulled the end off and used some sort of heat shrink on the ends?
Users browsing this forum: Google [Bot] and 30 guests
