HELP grinding noise from front susp?
by Calibravalver » Tue Apr 11, 2006 5:41 pm
Firstly hi all, my car is making a grinding type noise when cornering under medium - light acceleration. It sounds very similar to if a tyre was rubbing on a lowered car, only lots louder. It only does it now and again, about 4 times today, it's quite loud and disturbing, and comes from both sides (not at same time) Please advise......
Calibravalver
by Calibra Gordy » Tue Apr 11, 2006 5:45 pm
Have you checked your anti roll linkage is not broken/fractured and rubbing on the drive shaft, dont know exactly but it sounds a little like a similar noise as I have and this is the cause.
Calibra Gordy
by Calibravalver » Tue Apr 11, 2006 5:48 pm
Will go look now. When i go a bit faster on a curve like leaving a roundabout it wont do it, it does it when cornering under lowish speeds, sounds just like a rubbing tyre but much louder. Thanks for the info
Calibravalver
by Calibravalver » Tue Apr 11, 2006 6:03 pm
No, there doesn't seem to be anything untoward with the anti roll bar, or any fouling. The car is lowered mildly on what looks like springs only, wouldn't be more than 35mm tho by the looks.
Calibravalver
by dj_smurph » Tue Apr 11, 2006 6:38 pm
check your spring one might be broken
dj_smurph
by Phantom » Tue Apr 18, 2006 2:00 pm
could also be a CV joint
Phantom
by EY » Tue Apr 18, 2006 2:05 pm
Sounds like bearings on the way out mate.
