radiator fan relay which one is it
by ROG » Fri Apr 21, 2006 10:41 pm
Havent had a cooling fan for a week or so, driving with interior heaters blowing hot, once im driving its ok, just as long as i dont get stuck in a traffic jam!
I unplug the sender from the rad, it wont run when shorted, put a voltmeter on the fan end and theres no power geting there
so next thing is relays/fuses??? as the wires look ok
is there a rad fan fuse????, and where is the relay, ive got nothing in the relay box unde the bonnet apart fom a geat big green fuse
Behind the fusebox in the dash theres a row of relays, the worlds most awkward relays, its one of these????, but which one , it takes half an hour to get them back in changing from one cally to the other
or is it one of the relays in the fuse box???
ROG
by RobbieV » Sat Apr 22, 2006 7:51 am
Here's a list of fuses and relays should help you out [img]/smile.gif[/img]
<a href="http://www.v6calibra.com/docs/calibra_v6_fuses.htm" target="_blank">http://www.v6calibra.com/docs/calibra_v6_fuses.htm</a>
by vic_dub » Sun Apr 23, 2006 2:33 pm
Have you got a fuse/relay box in the engine bay.
If you have then its the blue colour relay which controls the fans.
by ROG » Sun Apr 23, 2006 3:53 pm
Still cant find the problem., the realy box has nothing in it, apart from a massive green fuse, that does wno knows what!
Ive pulled all the realys insude the dash off the stupid pc of plastic that holds them, im thinking of ripping them all out of the other calibra and changing all of them, but this wont solve the problem then it hopefully will be on the other cally though, if not then i may have to work out a complete new wiring to go to the fan
If its the blue relay in the relay box thats missing on mine, should it be the blue relay under the dash, or is that an extra blue relay??
ROG
by ROG » Sun Apr 23, 2006 4:08 pm
JUst found it, 1st thing i rechecked, the 4th fuse on the bottom row, the wire on the back had fallen off, all fixed now
ROG
by RobbieV » Sun Apr 23, 2006 4:44 pm
<!--QuoteBegin-ROG+--><div class='quotetop'>(ROG)</div><div class='quotemain'><!--QuoteEBegin-->JUst found it, 1st thing i rechecked, the 4th fuse on the bottom row, the wire on the back had fallen off, all fixed now<!--QuoteEnd--></div><!--QuoteEEnd-->
Nice one, must remember that one for future references [img]/smile.gif[/img]
Users browsing this forum: Bing [Bot] and 14 guests
