Camber
Camber
by ice » Tue Apr 25, 2006 12:15 pm
Ive changed the following on my car.
1) 18" wheels
2) Bilstein Premium suspension
3) Cav16 website camber kit
4) setup by power engineering
The camber suggested by cav16 should be between -1.25 and -1.5 i can only manage 1.5 on the drivers rear and -2 on the passenger rear. I dont know why this is. Ive had the components looked over for visable damage and there is none. Saying this the toe of the rear is spot on.
Any suggestions would be nice..
Question 2) I have a similar problem on the drivers front the camber is -1.5 where the passenger front is -.5 i have changed the following on the front
1) Wishbones
2) Drop Links
3) Track rod ends
4) Bilstein Premium suspension
5) 18" Wheels
6) Setup by power engineering
The tracking is spot on and the car does not wonder off or anything
Stu
ice
by Stupink » Tue Apr 25, 2006 12:52 pm
What offset are the alloys?
the lower the offset the higher the camber will be, vaux are ?ET49?
My camber was out even with maximum correction as i mentioned the other day, i put it down to that also. I cannot remember the figures, but i dont think it was as much as -2, it was -1.5 i think. I will try to dig it out later.
by ice » Tue Apr 25, 2006 1:02 pm
47mm offset lowered 35mm
ice
by Stupink » Tue Apr 25, 2006 2:04 pm
hmm.. won't be that then. lol.
I can't remember the paperwork that came with the bushes, did they have any lowering reccomendations or just a ajustment spec in degrees?
by ice » Tue Apr 25, 2006 2:28 pm
the bushes came with adjustment spec which were -1.25 to -1.5 both bushes on mine have been fully adjusted and the drivers rear is on -1.5 where the passenger side is -2.0 im thinking something could be bent ? but im not sure
ice
by Stupink » Tue Apr 25, 2006 2:36 pm
well i've found my old one, I know full well the car has been shunted etc, so i never bothered too much
camber
Fronts, L -1degree 31minutes R -1degree 28minutes Spec listed Max/min -1.25 0.05
Rear L -2degrees 23minutes R -2degrees 28minutes Spec listed Max/min -2.57 -1.37
by ice » Tue Apr 25, 2006 2:38 pm
mmm so could mine have been in an accident? i did a hpi check on the car before and it was fine. its just weird how its only 1 side thats out.
ice
by Stupink » Tue Apr 25, 2006 3:08 pm
theres a lot of data on the net, i think some of its in the handbook even, you could get your tape measure out and check basic point to point measurements, check the wheels diagonally for square, left and right wheelbase etc etc.
by ice » Tue Apr 25, 2006 3:10 pm
would a bodyshop be able to figure this out? as my car is going in on saturday for a freshen up.
ice
by Stupink » Tue Apr 25, 2006 4:10 pm
worth asking them to have a look over, i wouldnt worry too much though, your figures seem to be within the spec that was listed on the printout i have. by the time you sit in the drivers seat you're going to create a bit more camber on the right anyway.. hehe.. probably work out ok, if not you just got to keep eating pies untill it does.
by ice » Tue Apr 25, 2006 4:44 pm
u have a good point [img]/smile.gif[/img]
ice
by Chavtastic » Thu Apr 27, 2006 11:35 pm
Dude jack the back of the car up and take some measurements. Measure between bolts, mounting points etc... on both sides. If it's not symmetrical then yiou are looking at chassis damage.
by ice » Fri Apr 28, 2006 8:30 am
i had a look underneath yeaterday and the appears to be no damage visually either to suspension parts or the chassie, ill have a go as measuring some bolt distances over the weekend.
Cheers chav [img]/smile.gif[/img]
ice
by Stupink » Fri Apr 28, 2006 9:26 am
did you check the front subframe bushes when you had it down? perhaps one is worn/damaged and the subframe isnt sat straight?
by ice » Fri Apr 28, 2006 11:03 am
i didnt check the subframes at all to be honest [img]/sad.gif[/img] i just thought changing the wishbones would have sorted out the problem [img]/sad.gif[/img] god i hate cars [img]/sad.gif[/img]
ice
