Suspension travel question
by Phil » Thu Apr 27, 2006 10:10 am
A couple of years ago I lowered my 8v by 40mm on Gmax. However, I had 18's wearing a 45 profile so with people in the car (or without for that matter) the tyres fowled on the arches when driving in general.
So, what I can't decide is this:
Do I go for a 30mm drop? Or will this still rub with people in the car?
Or I could get 30mm drop turbo springs - these are stiffer, and so would withstand more weight?
What do you folks think?
Cheers,
Phil
Phil
by TonyDTM » Thu Apr 27, 2006 10:19 am
Add some coil spring assisters first and see how you get on...bout £20 quid tops a pair on ebay depending on the coil space. You'll need to measure the space between the centre of the coil and then get a pair relating to that size...approx 30 mil on rears. It should stop the full travel on the spring and hopefully avoid the rubbing. Then re-assess if still fouling the arches.
check this guys egay store:
<a href="http://cgi.ebay.co.uk/SUSPENSION-COIL-SPRING-ASSISTORS-AS3-TOWBAR-TOW-BAR_W0QQitemZ8056125504QQcategoryZ33653QQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/SUSPENSION-COIL-SPRI...1QQcmdZViewItem</a>
TonyDTM
by ice » Thu Apr 27, 2006 10:25 am
i would reccomment checking the offset of the wheel plus im running a 35 profile tyre and its fine no rubbing [img]/smile.gif[/img]
ice
by Phil » Thu Apr 27, 2006 12:10 pm
Guys, thanks for your responses, BUT (there's always got to be one)
the problems are: 1, I sold the 40mm lowering springs, and bought new standard springs. (it was a desparate measure as it was xmas) So I have no lowering springs to start with.
2, The tyres cost me £130 a corner and are brand new. Springs are cheaper than tyres, hence my decision to change springs in the first place when the problem occurred.
Phil
by Phil » Thu Apr 27, 2006 12:12 pm
oh, and I do have some bump stops to fit to the dampers on the front too.... they should help a little?
Phil
Users browsing this forum: Majestic-12 [Bot] and 19 guests
