how low?
how low?
by projectcalibra » Sat May 06, 2006 11:52 am
what is the best height for handling, and at what heights affect what size wheel you can have, ie if you go down 60mm will u be limited to 17" without doing arch mods? would you recommed doing the shocks at the same time?
other than shocks/springs, is there anything else to help improve handling?
projectcalibra
by dj_smurph » Sat May 06, 2006 6:35 pm
i dont think wheel size is a limiting factor when dropping the car but shocks and springs are a must if you want a decent ride, personally i wouldnt go too low especially if there is a lot a humps in the road, mine is 35-40mm drop and i wouldnt want to go any lower
dj_smurph
by projectcalibra » Sat May 06, 2006 6:39 pm
yeh i just had 60mm on cavi and it bounces over bumps and slides all over, was thinkin 40mm for calibra
projectcalibra
by robs_cal » Sat May 06, 2006 6:39 pm
If you want to lower the car by fitting springs, most deifnately use suitable shocks as well.
Polybushes will also stiffen it up a bit
Obviously though, the lower you go, the less room you have to play with when fitting wheels and kerbs then become a problem
robs_cal
