Repost Camber..
<!--QuoteBegin-ice+--><div class='quotetop'>(ice)</div><div class='quotemain'><!--QuoteEBegin-->the hpi come up with no problems, ive had a bodyshop check over the car and the only panel to have been replaced/ repaired was the drivers rear. If the car had been in an accident surely the panels wouldnt line up, maybe i should get it up on a jig just to be sure, if the chassie is bent ( Which i dont think it is ) then unfortunately the car will be broken for parts as im not gong to start replacing more parts<!--QuoteEnd--></div><!--QuoteEEnd-->
If I were you I'd get it on a jig. It would work out alot cheaper than guessing and replacing everything. As for the HPI I smashed my escort up twice got it repaired myself and the panels lined up perfectly and because I'd not gone throguh the insurance there was no record of it.
I'd also try to find out why the rear was replaced, you could assume it was rust but better to make sure.
