ABS Warning Light
ABS Warning Light
by projectcalibra » Thu Jun 01, 2006 11:45 am
ok, light comes on and goes off as normal when you start car, reverse is fine, but as soon as you start driving forwards the ABS light comes on and stays on. have tried doing a fault code check but it says its fine, because it is until u start moving. any ideas?
projectcalibra
by Will-Ni » Thu Jun 01, 2006 11:47 am
I Had The Same Thing Happen To Mine And It Was The Front Drivers Wheel Sensor That Was Faulty.
Will-Ni
by projectcalibra » Thu Jun 01, 2006 11:51 am
yeh thought it would be sensor issue, easy to fix, as in is it just replace the sensors? how do you know which one is faulty?
projectcalibra
by Will-Ni » Thu Jun 01, 2006 11:58 am
Its Just 1 Bolt And A Wiring Plug. The Drivers Side Was The First 1 I Changed And It Stopped The Light Coming On.
Will-Ni
by Leigh » Thu Jun 01, 2006 7:12 pm
Yeh, ABS is easy to change, annoying if it's not storing a code tho, my offside front went dodgy sometime ago but it stored the code so there wasn't any guessing/trying each sensor.
When you checked for codes which pins did you short? Apologies if you already know this, but the ABS codes are read using different pins to the normal ECU codes.
Leigh
by projectcalibra » Thu Jun 01, 2006 11:15 pm
pins a+K i believe, the top 2 pins anyway
projectcalibra
by Will-Ni » Thu Jun 01, 2006 11:38 pm
I've Been Told That Jacking The Car Up 1 Corner At A Time, Then With The Wheel Off The Ground Turn Your Ignition On And Wait Till The Abs Light Goes Out And Then Spin The Wheel And If The Light Comes On Then Thats The 1 You Need To Change. Has Anyone Else Heard Of This Method?
Will-Ni
by Rusty_CallyT » Fri Jun 02, 2006 12:37 am
sounds sus to me, whats it comparing the signal to if no other wheels are turning.
check and clean all the toothed rings and sensors before randomly changing stuff
Rusty_CallyT
by Leigh » Fri Jun 02, 2006 2:22 pm
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->sounds sus to me, whats it comparing the signal to if no other wheels are turning.
check and clean all the toothed rings and sensors before randomly changing stuff<!--QuoteEnd--></div><!--QuoteEEnd-->
I suppose it might show up if the sensors failing, I think from memory one of the two codes for each wheel is low voltage (or similar).
As Rusty says tho, for starters make sure the toothed cog and the sensor tip are clean of any accumulated crud, long before mine went properly faulty it was intermittently giving me errors, and when I checked the sensor tip was caked up with crud, quick gently clean and it was fine.
Leigh
by thecrow » Tue Jun 13, 2006 7:50 pm
ABS only activates over 10mph or something- so that's why the light comes on when you start moving.
Early ABS didn't log codes AFAIK- the later (2EH) system does.
thecrow
