Any Other Connections?
I Finaly Found The Yellow Plug Tucked In Behind The Headlight Switch! Why Its Over There I Dont Know.
When I Plugged In The Fuel Compter Nothing Happened, Not Even The Clock Came On.
Is There Any Other Connections To Be Made Or Fuses/relays To Fit Or Is The Computer Just Faulty?
Will-Ni
<!--QuoteBegin-wil3086+--><div class='quotetop'>(wil3086)</div><div class='quotemain'><!--QuoteEBegin-->I Finaly Found The Yellow Plug Tucked In Behind The Headlight Switch! Why Its Over There I Dont Know.
Is There Any Other Connections To Be Made Or Fuses/relays To Fit Or Is The Computer Just Faulty?<!--QuoteEnd--></div><!--QuoteEEnd-->
depends does a little F come up in the corner of the computer screen, if so then it is a fuse, think its fuse 15 but i'm sure that does the radio too so that would probably not work either
Cozy
