Switched Earth or Live?
by Twangy » Sun Jul 02, 2006 10:10 pm
Does anyone know if the door switchs controlling the interior light is a switched earth or live.
Thanks
Twangy
by Rusty_CallyT » Sun Jul 02, 2006 10:16 pm
switched earth... im pretty sure anyway
Rusty_CallyT
by Fraz » Sun Jul 02, 2006 10:53 pm
it supplys the earth to the light
by Twangy » Sun Jul 02, 2006 11:18 pm
Yep switched earth, cheers rusty. any idea if theres a permanent live in that vicinity aswell?
Twangy
by Fraz » Sun Jul 02, 2006 11:21 pm
plenty in the fuse box..thats near the door switch
by Twangy » Mon Jul 03, 2006 1:12 am
Ok for drivers door, but I need one for the passenger door aswell, but theres a sh*t load of wires running near the passenger door. Does the same wiring convention follow through the whole car? ie +12v red, Ground brown etc. I might just end up using the +12v from the head unit, it is half way between. I just dont like running too many wires near those heater control cables the alarm LED wires already obstruct one of them already.
Twangy
by Fraz » Mon Jul 03, 2006 1:39 pm
brown is earth..might help if you buy a cheap test light and find a live wire on the passengers side
or make one with a 12v bulb and a couple bits of wire
We Have The Power
by MR_TOAD » Fri Jul 07, 2006 5:55 pm
<!--QuoteBegin-p_single+--><div class='quotetop'>(p_single)</div><div class='quotemain'><!--QuoteEBegin-->Ok for drivers door, but I need one for the passenger door aswell, but theres a sh*t load of wires running near the passenger door. Does the same wiring convention follow through the whole car? ie +12v red, Ground brown etc. I might just end up using the +12v from the head unit, it is half way between. I just dont like running too many wires near those heater control cables the alarm LED wires already obstruct one of them already.<!--QuoteEnd--></div><!--QuoteEEnd-->
Not sure what is for you never said but you will find a red 12+ coming out of passenger door loom along with quite a few more it will be thicker than the rest
Ian
MR_TOAD
by ross85 » Sat Jul 08, 2006 1:52 pm
Are you fitting illuminated sills? For mine I got a live 12v from the fuse box on drivers side and the 12v from the alarm on the other side.
ross85
by ice man » Sat Jul 08, 2006 6:37 pm
Why do vauxhall have Brown - ve Earths and Black + ve Live wires - contrary to all other cars I've worked on - Strange.
ice man
Users browsing this forum: Google [Bot] and 14 guests
