For Those Who Have Lowered With Bodykit...
Quick question for all of you - how often does your front skirt ground out? My V6 is currently at standard height but I think it'd look a lot better if I just dropped it 30mm or so. My only worry is that it grounds out at the moment in some multi-storey car parks, so by dropping it I'm just going to be making the situation worse [img]/sad.gif[/img] The front skirt is ABS and not fibre glass.
I really think it'd look better dropped a bit but also want it to be as practical as it is now. Is such a thing possible?
Smurf
Neil, you saw how low my old SE4 was didnt you? That was a real pain but then again it was -60mm on 17's.
The worst place was the side skirt near the rear wheel as that was the lowest point and as you went over a bump with the front, by the time it reached the rear the front wheels were obviously back on the road closing the gap right down at the rear. I had a few problems with the front skirt, especially when driving in petrol stations and pulling in and out of junctions, which is one of the reasons why I got rid of the car.
You could always go for 18's and drop it and maintain a good ground clearance
cheers
cheers
DAN
From a mate of mine - tech help req'd
Here is a pic of my old SE4, I couldnt drive it anywhere in the end [img]/smile.gif[/img]
DAN
