2wd / 4wd suspension differences?
Just a thought...
Ignoring the different front springs for the V6 - I have a V6 *calibra* (edited as i am a muppet) and want to know what suspension i can fit - i know that the 2 litre suspension will have lower spring rate on the front, but what about turbo suspension?
I'm guessing the Fronts will fit fine (but with lower spring rate) is the fitting for the rear shocks different on 4wd? Are the springs different fitment?
many thanks [img]/biggrin.gif[/img]
Dex
Rusty_CallyT
Dex
calibra turbo suspension is the same as any other calibra. weight included. The only reason an LET will weigh more (net) is because of that heavey transfer box, diff and driveshafts. All of which I dont have so im running a super light cally T now [img]/wink.gif[/img]
- no such thing as a 2wd suspension. there is a 2wd floorpan though. Turbo shocks will be slightly better but vx played about with springs and shocks a fair bit. I have the full irmscher spec suspension on my SE5 which im guessing the shocks are Turbo. My LE had uprated rear springs but not front for some reason. Stahdard calibras get very little in the way of sport pack though.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
