Smash damage!
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->more likely std stuff like wheel balanceing, warped wheels, uneaven worn/damaged tyres, under/overinflated tyes, poorly mounted brake disks, unbalanced shafts etc etc.<!--QuoteEnd--></div><!--QuoteEEnd-->
i agree, check all this cheap fix stuff first before doling out the dosh to find you didn't need to in the first place. i had terrible wheel wobble and vibration all through the car. turned out i had the spigot rings missing, wheels weren't on tight enough, tracking was out, front wheels needed balancing and tyres were under pressure.
All fixed now and drives beautifully and even fuel consumption has got better.
Try it first
Rob
Try it first
Rob
