Rogue connector
Rogue connector
by Andy_cdti » Wed Oct 04, 2006 3:46 pm
Found this connector just dangling by the passenger side front wheel behind the bumper, any idea's?
Also where is the temp sensor meant to fix to as it was just dangling down next to it?
Andy_cdti
by ROG » Wed Oct 04, 2006 4:51 pm
the temp sensor fits into a hole on the bottom lip of the bumper, pointing up inside the bumper, i dont know what the plugs for, i suspect the headlight washers as ive never noticed it on the 16v with headlight washers, but ive got it on the turbo with no headlight washers
ROG
by callyben » Wed Oct 04, 2006 7:07 pm
thats looks like the pad wear sensor or abs sensor plug
callyben
by Andy_cdti » Wed Oct 04, 2006 7:08 pm
Cheers [img]/smile.gif[/img]
Andy_cdti
by Andy_cdti » Wed Oct 04, 2006 7:09 pm
<!--QuoteBegin-callyben+--><div class='quotetop'>(callyben)</div><div class='quotemain'><!--QuoteEBegin-->thats looks like the pad wear sensor or abs sensor plug<!--QuoteEnd--></div><!--QuoteEEnd-->
Hmm there wasnt that much play in the lead to get it all the way back to the brakes.... Seemed to be on same loom as the horn
Andy_cdti
by Rusty_CallyT » Wed Oct 04, 2006 8:28 pm
they are both round so cant be them
Rusty_CallyT
by ROG » Wed Oct 04, 2006 9:25 pm
im sure its for either headlight washers or an extra alarm horn/siren
ROG
by Robs-se » Wed Oct 04, 2006 9:26 pm
headlamp washer conector
by Andy_cdti » Wed Oct 04, 2006 9:48 pm
Champion, and I dont have headlamp washers so it can just be ziptied out the way [img]/smile.gif[/img]
Andy_cdti
